Do's, Don'ts and FAQ's
Started by speedyfix, January 27, 2004, 05:55:52 PM
tofujay
galing mo talaga migs! mabuhay ka!!  8)
DjiNN-ViRii
ask ko lang po kung need palitan ba yung spark plug pag nagchange oil ka? or pwede pa rin gamitin yung luma? thanks po!
Victorb
do not flush your engine using strong solvents
do use a oil based engine flush (caltex or motul)
poloy
don't do massive engine upgrades (turbo on a NA car, bigger block) if you can't handle the maintenance of the engine. Kawawa lang ung engine hirap na hirap umandar and hassle din for your wallet.
1996 car from hell
AutoPlus
Quote from: DjiNN-ViRii on February 27, 2007, 01:05:58 PM
Have your mechanic inspect your plugs, and let him determine if your plugs are already in need of replacement.
AUTOPLUS SPORTZENTRIUM
233 EDSA M
centZ
ask ko lang, what if di tumatagal ung suspension bushing (tama po ba?) ksi 3 months lang sira na kagad, lowerd ung car. anu ba dapat palitan dun? the spring? or whole suspension arm or suspension bushing again?  ???
ConanĀ®
Quote from: centZ on April 22, 2007, 06:30:57 PM
Where is this bushing located exactly?
ment
have it replaced elsewhere maybe the bushing given to you is not that good.
Or you can do research on PU bushings ... much longer lasting than rubber with the right hardness rating
either the bushing wasn't that good to begin with or else the chassis is misaligned kaya it wears out agad.
have it checked in velocity para sure kung di tumagal yung next bushing mo.
centZ
Quote from: speedyfix on April 23, 2007, 11:12:44 AM
sir san po kaya pwede i-pa-check? newbie lang po ksi sa mga gnitong sira...
Quote from: ment on April 22, 2007, 08:41:31 PM
ayt sir, san po makakahanap nun PU bushings?
Quote from: Conan on April 22, 2007, 07:32:57 PM
sa front wheel po cya prang cya ng hahawak ng gulong aside from the suspension, then my bushing nanakapagitan (ata po) churi di ko alam ksi mga terms..  :-\
velocity is the name of the shop. it's along shaw blvd at the intersection of 9 de pebrero.
mark_jdmek
PU bushings - Polyurethane bushings, meron nyan sa HCP malamang.or sa mga tuner shops sa banawe, qc, etc. good upgrade yan. kaya lang, i'd stick to OEM if you're on a budget.pero if performance and durability ang habol mo, by all means...bili ka energy suspension bushings kit.un nga lang, mejo pricey, and harder compound, so not as supple ung ride...i think.
kugmo
wow, a good thread a lot of recommendation of cool shops in the area...
prodigy
nice topic bro.. kung may pera ka go na sa set up. kc pag nagtipid mas malaki gastos pag nasira.. ;D
KitSir
Don't go to the same mechanic twice kung mabilis masira yung ginawa niya unless may warranty at wala ka na ulit babayaran sa repair. Kung hindi pabalik-balik ka doon. HEHE  ;D
Wassup!!! :-)
