My opinion about getting a good paintjob
Started by theveed, June 25, 2004, 06:44:32 PM
zinggoy
Quote from: goops on July 11, 2005, 08:19:57 AM
zinggoy, i might drop by your shop w/in the next few days...
no problem, i will be glad to accommodate you! just give me  a call or txt before you drop by just so that i will make sure that i will be there personally to assist you. thanks
Zinggoy's Paintworx
Has moved into a new home...
Fastrack, Capt Javier st., Brgy. San Roque, Pasig City
09186102994
Offers premier
herc
A good paintjob for me, there is only one. Zinggoy. A very very good paint job, can't notice the damaged part. I'm glad conan convinced me.
theveed
Automotive Paint Colors: What affects color match?
In this article I will be discussing the main factors of why color match is such a difficult task. I believe if you can grasp a little bit about what auto paint colors are made of and how their application shifts color, then you could understand what causes color to change and what you need to do to match them.
There are three basic ingredients in automotive paint:
Resin
Pigment
Solvent
The resin is the component that holds together the pigment in suspension, provides adhesion to the surface applied, and determines the quality and paint durability.
The pigment comes in a powder form similar to concrete, and the average aftermarket automotive paint mixing system includes about 100 colors or toners to be able to mix formulas including metallic and pearl paint colors.
The solvent is what provides the transferability, without the solvent the paint would be to thick in viscosity to transfer from container to container.
Now that you know the three basic ingredients, let's talk about the different paint systems and the applications for each.
Prior to 1985, the majority of the domestic cars had single stage paint from the factory. This was a major problem in trying to match the metallic colors for several reasons. In single stage metallic paints, the paint film is all one layer combined including the gloss resin, pigment, metallic and solvent.
The painter was challenged in painting a single stage metallic system because he only had 4 coats to achieve coverage and layout the metallic in a uniform matter by dusting light coats but still maintain an acceptable gloss.
This challenge was overcome by applying the first and second coat medium wet to achieve coverage and good bond to the surface. The third coat was applied medium wet and immediately followed by a mist coat until the metallic was even. The painter had to move fast and paint panel by panel and jump side to side to keep the overspray melting.
The secrete to this application was to keep the paint film wet, so when you mist the metallic on the wet surface it would flow to the bottom of the paint film and let the gloss resin rise to form the glass look we were looking for.
The same process is used in basecoat colors today except we are not worried about gloss because the urethane clearcoat is applied as the final topcoat and provides the deep gloss we need.
So what affects color match? Now that you know the ingredients and application process of automotive paint, I will explain what happens to color during the application.
Auto paint colors are made up of a combination of pigment colors and metallic sizes including pearls. The first challenge is the factory standard. Today, the average paint code has between three to seven alternates that are worth formulating. There is actually more but the auto paint manufacturers have narrowed them to down to keep the databases simple to use.
David Lee Tong
Founder: Pinas Auto Detailiny
theveed
So why do the car manufacturers have so many variances? Most car manufacturers have three major paint suppliers. The manufacturer decides on a standard color for production and submits a painted sample to their suppliers. The paint manufacturer then produces a formula for the "standard sample" and is allowed a tolerance of plus or minus 5% when they deliver the paint.
This is the first problem because the plant in the east coast may be getting a 5% shade greener on a blue metallic standard and the plant in the west coast may be getting a 5% shade violet on the same blue metallic standard. When compared side by side, they look like a completely different color. This is the reason the paint manufacturers usually have the standard formula followed by two alternates. If the alternates are not available, the painter in the body shop usually mixes the standard formula and tints it accordingly.
The second reason for variances in paint colors is the metallic color applications. The metallic colors are now classified in 7 categories. Extra fine, fine, medium, medium coarse, coarse, and extra coarse. The metallic colors control the value (lightness and darkness) of the color similar to what white does in a pastel color.
Metallic colors will cause variances in color when applied. Temperature, paint film thickness, flash off time between coats, fluid tip sizes, speed of the spray gun, surface type (Plastic or Metal) and humidity will all cause the color to shift lighter or darker.
The rule of thumb: the longer it takes to dry, the darker the color will change as it dries. This is caused by pigment floatation. The metallic flakes will settle down to the bottom of the paint film and push the pigment up causing the color to shift darker.
The reasons above only mention the variables at the car manufacturers level. So what happens to a color after three years of sunshine? Many people think that colors do not change, but they do, and I will prove it. If you own a car that is at least three years old and has been out in the sun most of the time, remove a pinstripe and you will see the original color when you bought the car.
The sunlight has ultra-violet, and has absorbed some of the pigments. Blue metallic colors sometimes shift to a greener shade, and reds will turn pinkish or more orange. The auto body shop has to deal with matching an oxidized color in addition to new OEM colors. The new paint to be applied will look brighter and cleaner but the rest of the car looks dead even if you polish it.
Auto Body Shops today have a greater challenge than just color match. The texture or (Orange Peel) also has to match the original finish in order for it to look pre-accident condition. This can be accomplished by using the proper spray gun, polishing equipment and experience.
David Lee Tong
theveed
Why do plastic bumper covers change color? Every once in a while we get a phone call from body shop client that is trying to deliver a car and their customer will not take it because the bumper looks different than the car. The most amazing thing is that the bumper and the front end of the car was painted at the same time, with the same gun, same air pressure, same temperature and the same paint.
How do you explain the bumper color change to the customer? Plastic bumpers will always change color especially in metallic colors. The plastic has a static charge and the metallic paint will settle different than on the sheet metal parts, causing pigment floatation that will shift the color darker or lighter. The other reason is surface temperature, if the sheet metal is colder, the bumper will look lighter, if the sheet metal is hotter than the bumper, the color on the bumper will look darker. The third reason is flex additive. If the clearcoat is applied on the bumper with a flex additive, it will shift the color slightly.
How do you prove your point after explaining this to the customer? Your customer will probably think your trying to fool them with this explanation, Luckily, the majority of our body shop clients in our area are dealerships. So they walk the client to the show room floor and point out that just about every car on the lot with a metallic color has a shade different on the bumper covers, front and rear, plastic door handles and plastic mirrors, all have different shades. Most clients are more at ease when they realize that they bought the car this way but had never noticed.
Here are some tips you should consider when spot repairing:
Always blend the color to achieve color match. Do not panel paint and expect a quality color match, even if it looks close enough, blend it! You have too many variables to deal with.
Always tint the value first before tinting the hue. 80% of the time it will hit or it will be bendable. Never try to blend a color that is off on value, it will always look to dark or too light where you spot repaired.
David Lee Tong
n0n0
anu ba magandang dami ng coats (2, 3, 4 coats) para sa base and clear coat???
thanks ;D
chuckster
zinggoy, i'd like to ask for your oppinion on car paints... i just had my car repainted lately, the painter used RM Diamont paint. OK ba yun? I liked the color from the swatch book eh pero I don't know if it would be as good as anzhal... The painter said its like anzahl din pero i'm still not sure eh. i'm spooked coz maybe it would bubble soon... pero he used anzhal primer and clear coat...
I'm also kinda spooked kasi i picked a pearl color eh, mahirap daw retouch kahit pre-mix yung paint... What do you think?
thanks
theveed
Wala pong kinalaman ang pag bula ng paint sa brand ng paint. It's all in the skills of the painter and how well it was prepped before painting.
David Lee Tong
Lutheran
im also a newbie here, just getting some inputs, coz right now im repainting my car, dami na kasing mga scrathces, and also un top coat parang natatanggal na, so ive decided to re-paint it, piece per piece. inuna ko lng un bumper and hood, can some one giver me step by step sa pagpapaint, kahit un basic procedure lng. para makopya.. salamat po...
zinggoy
hi bro lutheran!
kindly check the thread "questions about repaint...". you can find good tips there regarding painting.
Zinggoy's Paintworx
09186102994
Offers premier
ryejb
Hello guys!!
Im a newbie here. Please help me out.
Plan kong ipachange color ang kotse ko. Medyo madami n ksing scratches. Toyota Corolla GLI  '97 (Big Body) Tom's version sya, Silver Mica ang kulay.
My question is ano b paint mganda gmitin? meron akong natanungan n shop n ang gamit nila e sikkens. 35k dw scrape to metal. ok n b yun? Any suggestions s shops, type of paint, or idea of color n bagay s Tom's Corolla?
Also pag scrape to metal b dapat aalisin lahat pti yng makina? para yng mga loob at ilalim e mapinturahan din?
tnx.
BAGSIK
Zinggoy
Im planning to change color my corolla big body from dark to light color, its paint is still original but faded.
What would you recommend washover or strip to metal?
Thanks!
zinggoy
Quote from: BAGSIK on May 18, 2006, 03:51:35 PM
Zinggoy
Thanks!
hi bro bagsik! sorry for the late reply. if your paint is still original, i would suggest just to sand it down properly, seal it with a good primer then paint. no need to strip it down.
Zinggoy's Paintworx
09186102994
Offers premier
Schon
hi Jing, si Jeff e2...
pa pm naman kung magkano aabutin pahilamos ng cr-v ko and kung gano katagal abutin...thanks
Bigbert's Professional Detailers
Units 1 & 2 Robbinsdale Bldg,
14 G. Araneta Ave., QC
Tel:  416-9305 ; 415-0979
Units
theveed
Quote from: Schon on June 04, 2006, 08:19:21 AM
Uuyy nainggit kay Vince hehehehe
David Lee Tong
