amp for three JL10wo's....at 4 ohms/sub
Started by 1min.shuffle, October 01, 2004, 11:38:51 PM
1min.shuffle
advise needed on which amp would best suit 3 pcs of JL10wo's (4 ohms/sub) in a sealed enclosure.  budget of between Php 6-8K, thanks.
another option of mine is to install 2 JL12wo's (4 ohms/sub)....same budget for the amp....preferrably a class D mono.....thanks in advance!
< jao >
Hi 1min!
Wiring 3 subs with a single amp may indeed require you to use a class D amp which can handle lower impedances but guess finding a class D amp with a budget of 6-8k may be difficult.
Authorized Distributor of Belden Cables and Wires. For inquiries, please contact me through email at [email protected]
If you'll wire the three subs in parallel,  you'll get a 2 ohm final impedance. Get a 2 ohm stable mono block (or 2-channel) amp
As for the wattage, take note na hanggang 200w lang ang kaya ng w0 (ideal nga eh is 125-150w, 200w is almost pushing it to the limit na). :)
KeWlRyDs
wiring three 4ohm voice coils in parallel will give you less than a 2ohm load. if i'm not mistaken, it will give you a 1.3 ohm load.
just a jao mention, finding a class d amp within you budget will be difficult. the amp will also be putting out more power than what the speakers are rated for.
Quote from: kewlryds on October 07, 2004, 10:38:44 AM
My bad, i was thinking of 8 ohms :) Thanks for the clarification dude.
1min.shuffle
thanks for the replies....already got one pair of 12WO's (4 ohms each).  purchased two seperate amps (2 channel/bridged at 4 ohms gives out 200 watts RMS) one amp dedicated to one sub..i think this would work but would have to watch the adjustment on the gain i guess....thanks.
totsss
pare san ka nakabili ng subs mo? magkano kuha mo?
