Routing wires
Started by meowmix, November 10, 2004, 10:55:55 PM
meowmix
If you place the amp at the trunk, and this amp will power a sub, as well as front seps, is it ok to have the RCA cables from the HU to the amp, bunched together with the speaker wires from the amp to the front seps?
In this proposed set-up, the RCA cables and speaker cables will run at one side of the car, while the power cables will run at the other side of the car.
Is this the best wire routing?
KeWlRyDs
although running the speaker and RCA wires on one side of the vehicle doesn't really result in system noise, it's best to lay down the wires seperately.
