recommended oil
Started by lightyear07, March 10, 2008, 12:11:25 PM
lightyear07
question lang po mga sir, ano po bang recommended nyo na oil para sa 95' GLi ko? nasa 120K na po tinakbo niya..balak ko na po kasi magpa change oil eh, 2nd hand ko lang po kasi nabili 'to, tinanong ko dun sa pinagbilan ko kung anong oil ang ginagamit nya, sabi nya top1 oil daw. ok lang po ba yun? sensya na po, newbie eh. suggestions and opinions are very much welcome from you guys.. TNX!  ;D
Mo Cool
Quote from: lightyear07 on March 10, 2008, 12:11:25 PM
Use MOTUL Multipower 15W50 Php 325/Liter. better kung mag engine clean k muna mataas na kasi odo ng car mo.  san b place mo???
MOTUL FOREVER
get a 50W, API SL oil. 20W50 or 15W50 would do.
lightyear07
ok po, ang alam ko din pag mataas na yung odo dapat yung oil na gagamitin eh medyo thick yung consistency, tama po ba?,
medyo may kamahalan yung motul eh, hehe..di pala medyo, mahal pala talaga para sa isang student na kagaya ko..hehe! ano pa po ba ang medyo ok yung price at mgandang brand na oil?  :)
I think Shell Helix 20W50 (the yellow one, not the red one) and Valvoline 15W50 are good choices for W50 oils.
lightyear07
ok tnx, ano po ba mga dapat ireplace na or ipa-check na mga parts kapag nag pachange oil bukod sa oil filter? para sabay sabay na..
The time na lumabas ang Lancer GLi '94 API SG pa ang recommended and highest rating pa noon. Although most manufacturers would agree that the latest api rating oil should be poured into the motor, high mileage motors may have different needs already compared to the newer cars. The thing with the latest API SM is so much of the anti-friction additives have been reduced already. Compliance with emissions law is the major consideration for this move. IF you'd also notice most of the High Mileage oils have more of these additives and has lower API ratings.
lalakas ka lang sa gas with the 50wt oils. i'd suggest a 10w40. it'll give you enough protection and it'll make the engine more fuel efficient.
marami naman mineral oils that will suit your budget.
ment
sir 10W40 oils titipid ka pa sa gas .....
good experiences with shell helix blue ... semi synthetic ito .....
OK din motul Htech 10W40 .... used this before  and loved it ....
tali lang ako sa CASA ngayun kasi :(
tad
try mo mobil super xhp plus 15w-40.
tip_tipid
I have been using Shell Helix Semi Synthetic (BLUE Container) for my late 93GLXi first owned ever since and the engine runs like new up to now. Change Oil Filter every change oil as well.
M350Z
Quote from: lightyear07 on March 10, 2008, 06:09:16 PM
Since gusto mo makatipid AUTOPLUS can give you oil change package for only 1,800 MOTUL MultiPower oil, free filter and labor + multi point vehicle inspection. for info. visit AUTOPLUS Sportzentrium at 233 EDSA (South Bound) Mandaluyong City.  :thumbsup:
i changed my oil to mobil1 10w40. tanong lang kung ok ba ang 10w40 or should i use a 50weight?car is 20+ yrs old...average temp here goes from 85-95F(29-35C) and sometimes 100F up
also the only 50 weight oils that are easily accessible are mostly conventional oils. and the 100% synthetic ones are sold per quart w/c is a lot more expensive. and the car needs 6.87qts so kinda crazy to buy it per quart thats why i buy a 5qt jug.
so should i use a 50weight conventional or mobil1 10w40?
tad
Quote from: aid03 on May 22, 2008, 01:02:22 AM
Suggestion ko lang na you should continue to use mobil Super S plus 10w-40. Since, it is already synthetic blend. It has a higher temperature limits compared to conventional oils. Mas fuel efficient pa. Pero na sayo na un kung gusto mo gumamit ng conventional oils.
just so you know that the superior M1 0W-30 did. Check the analysis.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1156983#Post1156983
Good? Bad? you decide.
