06 crv throttle respone
Started by Qkid, August 06, 2008, 01:36:43 PM
ae92_jaf
it's not really a problem with the units.siguro honda just designed them that way.was able to drive a friend's FD...didn't mind the split second delay since geared for comfort naman ata karamihan ng new units na lumalabas ngayon eh.really wasn't looking for ultra fast response kasi la naman akong ginagawang aggressive driving para kailanganin yung ganun klaseng reponse.
ILISPEED AUTOCLUB
oz
guys i'm also experiencing this problem on my cr-v 06 model, 2.0 . 2.0 din ba sainyo? sa 2.4 kaya ganto din? date ang gamit ko 93 octane, nung nag upgrade ako to 95 octane, mejo lumakas ng konte hatak, pero after few months, bumalik sa date. pano kaya ma-solve to?  ???
bimmerclub.ph
club 4:20
try resetting the ecu, remove the battery and replace it after 10 minutes and see if there's a difference.
nathaniel
ito ang common observation ata sa mga k-powered crv(gen2-up)... Here's what i did so far to address the issue: palit fuel filter, reset ECU, use XCS, adjust spark-plug gap to 1.1mm(ginaya ko lang sa Civic ko), DIY ng groundwires(throttle, valve-cover, tranny). Nawala ang tope/lag... Pero bumalik eh(after abt 3mos), pero di na gaya ng dati. Baka may kulang pa sa ginawa ko. Or, tlagang ganun na sia. ???
www.carloansphil.com
carloan/car re-financing
415-7333  0922-8222591
baka it relearned it na kaya balik sa dati. do the reset and see if it improves.
nathaniel
.. yup sir speedy, did the reset again.. and nag-improve uli. No lags during my 2-hr trip yesterday(plus 2hrs back pa). Hope permanent na mwla na.
stradale
If you desire throttle response, don't buy automatic, especially for high revving small displacement engines.
tisay
use a higher octane or check your spark plugs and tune your car...
marktriton
hi
i have a question guys,
anu ba yun drive by wire? lhat ba ng car now eh ganun ang design. kahit ba sa pick up?
oz
thanks speedyfix and tisay for the suggestions.
Quote from: stradale on April 09, 2009, 02:14:45 PM
i agree
bimmerclub.ph
club 4:20
