city headlight?
Started by litoskid, September 18, 2008, 10:48:23 PM
litoskid
sir just got my city 07 and i want to replace the headlight... sa mga nakakaalam po anu po ba stock headlight ng city?
if ever palitan ko po ng Philips XP bulbs ok lang po ba? hindi po ba ako magkakaproblema  sa wirings? hindi po ba masusunog?
pati po sa foglight papalitan ko din sana ng bulb... anu po suggestion po nyo? yung bulb na hindi na ko magpapalit ng wiring mga sir...
El
h4 yung headlight bulb ng city
litoskid
h4 na yun sir? if ever palitan ko po ng philips xp h4 parehas lang po brightnes nya?
anu po pala diff ng h4 at h7 sa philips xp? kaya po ba stock wiring ng city yung philips xp h7?
El
yes, h4 nga, i havent tried philips, so i cant tell
ang alam ko kung h4 ang stock bulb type ng headlight, h4 lang din ang pwede
so di pwede h7 sa stock headlights ng city
DrivenByTheMachine
yes you can replace your stock h4's with philips xp h4's without having to modify your wiring.  Philips XP has the same wattage as stock but has a noticeably brighter and longer beam.  Go for it!  :thumbsup:
Quote from: litoskid on September 19, 2008, 07:57:08 AM
dual beam (60-55W) ang H4; while the H7 is single beam. H7 is used for low beams like with the fortuner.
It's cheaper to produce H4 reflector heads kc. But some manufacturers would make separate hi/low reflector heads.
H7 Standard bulb produces around 1600 lumens;
H4 Standard bulb produces around 1300 lumens
Yes get the XP for your city. nothing to replace for the wiring. If i were you try installing one first, while leaving the stock bulb on the other so you can compare the viz. just a suggestion. :thumbsup:
