h3 for my foglight
Started by john5, January 03, 2010, 11:11:19 PM
john5
finally i decided to upgrade my bulbs both my headlights and my fog lights with just an ordinary halogen bulb rather than having an hid which can cause too much glare since i have only halogen housing.i want to replace my h4 narva all weather with philips xp.
question:what's the best h3 bulb for my foglights?gamit kong bulb is flosser ano kayang magandang re[lacement?i'm more particular sa light output than the color since it will emit a yellow light because my fogs are painted yellow.i'm confused what to choose preferably philips din kunin ko.ok na ba ang crystal vision 4,3k?any other suggestions?tia
kung output hanap mo, I suggest the Philips Power2Night H3 +50%. but if you want that yellow look, I'd go for Polarg Pure Yellows.  ;)
john5
power 2 night?wala pa ako nakikitang ganon sa malls,i'm thinking kung mag diamond vision or crystal vision ako.i'm using a yellow tinted glass na kaya whatever my light color is magiging yellow din yung output nya ;)
ConanĀ®
Quote from: john5 on January 04, 2010, 09:10:12 PM
Diamond Vision and Crystal Vision are blue tinted bulbs to make them appear to have a white output. In doing so the actual light output becomes weaker. It's up to you if you want to install handicapped bulbs.
I suggest you visit the shops in Banawe. I recall seeing Power2Night on display in GoldCars.
btw, I think using Crystal Vision or Diamond Vision on yellow-tinted fogs would result in a "green" light since you have a bluish-output bulb being being filtered through yellow tinted glass/plastic. ;)
and one more thing, I forgot to mention the Osram All-Season! I also recommend that!  :thumbsup:
john5
Quote from: Conan on January 04, 2010, 11:13:08 PM
ay sorry mga sir mali pala,i'm also aware of these so called "cool" hid look bulbs.vison plus pala ang nasaisip ko which offers 50% more light output.
dean
how about the osram all-season bulbs?
Quote from: dean on January 26, 2010, 04:28:21 PM
they're also good! I use those on my Altis' foglamps.  ;)
