after oil change...
Started by blacksharkfin, January 12, 2010, 10:15:22 PM
blacksharkfin
gud day! just want to know if its normal for the oil to change color its color after running 10km? before its been change the color is red... then fill with new oil and check the dip stick its clear na. and after running in 10km, (from Shop to garagge) i check it again, nag iba na kulay, naging red ulit...  :surprised: possible po kayang my natira pang old oil? even they use pressurized air for pumping it out daw? new oil is 10w 40? ultron rallye. do i have to change it again? btw, flushing the engine is also done i just cant remember the brand of the engine flush...
are you talking about a/t fluid? or engine oil? baka iba ibang dipstick nahuhugot mo. red kasi sa a/t fluid
blacksharkfin
engine oil po. red or dark red or maroon in color po xa.
before that san ka nagpa change oil and what oil did you use? normally clear/brownish yun at first, then nagiging dark/black after a while.
blacksharkfin
same gas station po., ultron touring ung oil b4..., now ultron rallye po xa.
not sure kung bakit naging red yung oil mo... baka nagleak yung tranny fluid sa engine, just a wild guess. a/t ba yung kotse?
blacksharkfin
manual po. wala naman leak. i was wondering na posible kya d nai drain lahat ung old oil? i try ko din kaya ung every 1000k change oil? until maging clear? and one thing, oki lang kaya kung buksan ko ung valve cover just to see inside? kailangan paba lagyan ng sealant pag i balik na? thanks!
that should be ok. you really can't drain it fully naman unless you pull down the oil pan so baka naman it was just what was left mixing with the new oil.
blacksharkfin
oki thnx! maybe i'll try changing it for every 1000km for 3x to make it really clean. just like what the other have done. then go for the Motul motor oil.  :rock:
yeah should be ok naman to do it. it's not really bad naman for it to get dark. that's the oil doing its job.
blacksharkfin
oki thanks sir...!  :thumbsup:
pnmra
aiinas
sir, in my opinion , some oil mas matagal mang-itim sa other maybe kaya the color changed at 10K
