Project Lancer Box Type
Started by CJ_Perez, April 28, 2011, 05:35:22 PM
CJ_Perez
Hi guys and gals... Masters of the forum and the information...
I found a Mitsubishi Lancer SL near where I live.
The owner is selling it to me for 25k.
PROS:  :wav:
1. Good engine (clean engine bay and no leaks)
2. Naka Mags na po sya na kinse (preferred ko pa rin 13 na off set).
3. 5-Speed na po sya.
4. May Air-Conditioning na po
Bale bottomline po eh good running condition pa po sya 1400 and according sa owner ay tipid sa gas (Binangonan to NAIA in less tha 400php).
CONS:  :dontknow:
1. May pagawain po sa body in terms of pogi color looks.
2. Yung mga sidins eh po eh palitin (kung magseselan).
3. Kailangan po ng matinding linisan.
4. Gagastos pa po para mapaganda ng husto ang tayo.
5. Hindi na po unat yung kaha (pinto and counter panel).
6. Door Lock system po ay palitin na rin
First owned (bought with my own money) po ang oto and I believe I had this blood for old school kasi mas naguguwapuhan ako sa old school na oto. I'm tempted to buy this then I will just work on it as a project. Siguro naman in 1 year time kumpleto ko na restoration process nito.
I need your opinion (PROS-CONS) 0927.644.0172 or [email protected]
salamat po sa magrereply.
sic.zero
So what happened now on your setup?
Butch12874
1, ang parts niyan ay marami at mura!  2, make sure to put the biggets radiator that can fit!  the original radiator gave me overheating problems in heavy traffic!  3, aluminum ang cylinder head mo, have it checked thoroughly!  4, buy the best timing belt!  kapag napatid yan while engine running, wasak ang cyl. head mo!  5, mura maintenance nya!  6, matibay ang suspension niya, pa check mo ang subframe chasis niya kung good condition pa.  pag kinain na ng kalawang forget that car.  7, palitan mo na lahat ng electrical wires niya, get a good electrician!  8, i installed a pajero engine oil cooler, great help!  i have an old box type here na nakatabi pero, kapag inayos ko uli sya, i plan to install an old toyota 5R engine.  engine ito ng toyota crown noon, 2.0 liter!  very durable and powerful!  steel cylinder head and it is chain drive, not belt!  my problem, wala pa akong makitang 5R!!  O nga pala, friend ko noon naglagay ng toyota 12R sa box type niya and he enjoyed it!  1.6 liter ito and also very powerful and durable!  kinabitan niya ng weber carbs!  good luck!
