hid or halogen
Started by atog1, September 05, 2011, 06:57:28 AM
atog1
good day mga expert..advice naman po..anu ba talaga may ok mag hid 6000k 35wtts ako or halogen philips xp 55/60..sabi kasi ng iba pag hid daw madali mapundi at sabog ang ilaw,pero maliwanag talaga...un philips naman malakas daw sa batery,nakakasira ng headligth kasi mainit,stress batery and alternator..anu po ba talaga ang the best para sa car natin..thanks AI..
if your car already has projector headlamps, it's all right to put HIDs. but if you only have halogen reflectors, get halogen.
btw, yung sinasabi mong sabog ang ilaw ay gawa ng HID na nakakabit sa reflector headlamp. hindi tama ang buga ng ilaw di tulad ng naka-projectors. saka yung madaling mapundi, halos lahat ng HID na binebenta dito ay gawa sa china. nagkaka-talo lang sa warranty.
atog1
sir salamat sa reply..
stock headligth lang to nasa car ko..but sir totoo ba basta tama ang laser alinement ng hid wala problema sa other vehicle na kasalubong,sabi sa LA CAR dapat daw may tama laser alinement kahit stock HL..
napansin ko kasi sa HL ko sir para nag chip un loob,dahil daw sa halogen un mainit kaya nasisira..
gusto maka sure kung ano mas ok para sulit sa gastos..
make sure na okay ang warranty at aftersales ng HID na bibilhin mo.  ;)
HyperPower™
Go for Halogens, they're better, usually.
Hyundai Accent 1.4 2012
Hyundai Getz 1.1 2009
Suzuki Celerio 1.0 2010
Mitsubishi Galant VR6 1997
Mitsubishi Galant 2.0 1990
Toyota Corona 2.0 1991
michaelchad
#5
Kahit ipa-laser alignment mo ang halogen reflector headlamp na naka-HID, sabog parin ito. Worst case scenario, magiging sobrang baba yung aim ng beams. Useless on the road. Stick to halogens unless you'll have your headlights retrofitted to projectors.
Quote from: michaelchad on September 06, 2011, 11:11:12 PM
correct! only get HIDs if your car has projectors or if you retrofit projectors to your headlamps. ;)
atog1
copy mga sir..i go for halogen na lang,1 thing sir..un ba philips xp 55/60 para din daw hid 3000k tama po ba?o un 100watt un?...anyway sa stock 55/60 pading ako..salamat mga expert galing niyo... :wav:
Quote from: atog1 on September 07, 2011, 09:18:57 PM
Philips Xtreme Power (XP) uses 55 watts and is the same color temp as stock. (but is much brighter.)  I highly recommend it!  :thumbsup:
atog1
mga expert totoo ba if may may payong un loob ng HL less un glare ng hid?may nkita kasi ako car naka hid din pero di ganu nkakasilaw nun nilapitan ko may payong un HL niya..depflector yata tawag dun..palagay niyo sir???
it reduces the glare. but it doesn't totally eliminate it. I suggest going for high performance halogen bulbs like Philips Xtreme Power or a full-on HID projector retrofit.
Quote from: atog1 on October 21, 2011, 02:09:41 PM
Sir, Merong D2S/D4S na HID na designed lang para sa projector type headlights. Kung gagamitin nyo sa reflector headlights Dapat gamitin ninyong HID bulb ay D2R/D4R.
Kung mapapansin nyo, ang Subaru forester ay reflector pero naka HID din.
Quote from: Manga on October 21, 2011, 08:53:32 PM
the current honda accord also uses HIDs on its reflector headlights. I think it uses D2R type HID bulbs.
atog1
so mga expert d2r and d4r can be use on my 2001 honda civic tama po ba..
john5
pwede ka din mag philips extreme vision mas bago to compared sa xp na 80% more lightoutput,eto 100% more.same price lang sila sa blade
