Can you suggest alternatives to the OEM Mitsubishi ATP SP III?
Started by roydok, July 25, 2012, 06:33:23 AM
roydok
Hi. Can you suggest an alternative Automatic Transmission Fluid (ATF) brand other than the OEM Mitsubishi ATF that is the same spec (Mitsubishi ATF SP III) and is locally available in the Philippine market? The current ATFs being sold locally the last time I checked (i.e Petron, Caltex, Shell, Castrol, etc...) only meet the Dexron III spec and not the Mitsubishi ATF SP III spec.
Thanks.
Amsoil SP III ATF but I don't know if they are available here. Also ask people from Hyundai/Kia, I think they use the same tranny spec as Mitsu.
I think Motul has the Multi ATF that will match that spec.
