2 din HU's? CRV HU?
Started by Lynx2k2, January 04, 2003, 07:50:56 PM
afrodikk
Mga Chief,
Sya nga pala, yung CRV HU ang line out nya rear (L+R) only!
Pano iaamplify yung front seps from this rear line out? Subs kase pwede passing through a xover d ba?
Help pls. Thanks.
afrodikk ??? ???
mike_parak
sure ka L + R?, baka F + R?
Billabong
Quote from: afrodikk on April 22, 2003, 11:40:35 AM
Mga Chief,
Help pls. Thanks.
afrodikk ??? ???
yup, possible na L+R ang pre-outs ng head unit.
IMm29
Quote from: Billabong on April 22, 2003, 09:15:12 PM
so that would be 1 pair of RCA preouts in this case right?
afrodikk,
in my case, only 1 of my 2 pairs of RCA preouts were used for my front seps and sub.  they were wired to my 4 channel amp in parallel, with the built-in xover filtering out the frequencies (low and high) appropriately to the corresponding channels (1&2 for the seps, 3&4 for the sub).
HTH.
The Devil Drives Prado
What? 1 pair lang ang preouts for this not-so-entry-level head unit?
E di you won't be able to maximize the DSP capabilities it has ?
Teka , does it have DSP features such as listening position, ambience, etc. etc. or digital EQ lang?
mike_parak
Quote from: IMm29 on April 23, 2003, 09:12:31 AM
afrodikk,
HTH.
bakit nga ba winire ng ganon yon? why not use the other preout for the sub?
IMm29
rAImond, mike,
teka, yung wiring ko ba yung tinatanong nyo?  hehehe   ;D
honestly, i don't know.  i wasn't paying close attention when they installed my wires.  i only noticed that the connection was that way when i started experimenting with it with an xover.
it has 2 pairs of preouts, and some DSP features (http://www.expressmotion.com.sg/kenwood_dpx8020md.htm).
mike_parak
hmm, try fading all the way to the rear, kapag sub lang naririnig mo, yung rear preout yung gamit sa sub.
IMm29
Quote from: mike_parak on April 25, 2003, 08:33:37 AM
dude,
isang pair lang ng RCA yung ginamit for the seps and the sub.
afrodikk
Chief IMm,
Saken hindi yung nsa pic ng url na mention mo eh, mas low end unit saken pero me dsp nga. Alam ko 1 pair lng tlga yung line out red +white only tapos fader ko pag todo rear tlgang yung amplified section lng ang dinig.
Mga Chiefs,
Assuming lang nga na talagang rear lang ang me line out, obligado ba na mag speaker input to the amp ako for the front seps?
jolog radyo eh...
afrodikk
Well at least your situation is much better than those guys owning an Altis 1.8 G, iyong 2-DIN nun walang preout (accdg. to Conrad). Mas masakit iyon diba? :)
For your question, you could:
1.) find a speaker-to-line-level converter for  your head unit. Kenwood yan diba?
2.) Get amps with speaker level inputs.
HTH!
afrodikk
Chief rAImond,
Most of the amps i have encountered have speaker level inputs. I have orig Alpines that have.
Question: How does sound quality/ fidelity compare with that of line-level inputs to the amp? If i am using speaker level for the front seps via an amp would this be comparable/ as good as using line level?
thanks,
afrodikk
afrodikk
Mga chiefs,
Ako'y nagsusumamo sa mga may manual ng head unit na kenwood ng 99 CRV, kung pwede lang po pakopya ako o pabasa man lang.
nagpapasalamat ng malugod,
afrodikk
IMm29
Quote from: rAImond on April 25, 2003, 10:29:08 PM
yikes!  2DIN without a preout?!?  masakit nga.
