7450 sub output settings
Started by vin888, April 06, 2003, 10:49:23 AM
vin888
anyone know kung san dapat naka set yung settings mo kung may subwoofer ka
di ko alam kung dapat sa subw1 or  non-fading output nakalagay
rear sp"full? or
rear sp SW?
sw control: int?
sw control: ext?
ment
#1
Quote from: vin888 on April 06, 2003, 10:49:23 AM
rear sp"full? or
rear sp SW?
sw control: int?
sw control: ext?
Dapat naka set sa "subw1" ... non-fading is usually reserved for rear speakers ... that is how i understand the manuals ....
I'll try to explain as how i understand it ...
rear sp : this is to set the rear speakers wires of the head unit for "FULL range rear speaker" function or "SubWoofer out function" ... kasi nga diba capable yung head unit mag drive ng 4 ohm sub directly (called Direct Sub Drive).
SW Control : or SubWofer Control, simply internally  or externally control the subwoofer. This is for the Sub-out rca jack of the head unit. Pag naka internal, mako control mo sub levels, phase, thru sa head unit by controlling the signal from HU to amp. Externally means all adjustments are done outside the HU and the HU only acts as signal source only. ;D
HTH!   Read the manual again ....
vin888
yung HPF
dapat ba naka off? or nasa 50,80,125??
IMm29
Quote from: vin888 on April 14, 2003, 12:14:04 AM
yung HPF
this is usually for your separates.  if your amp doesn't have a built-in crossover, or if you disable that function, you can control the frequency at which to cross your seps thru your HU.
if you leave it off, chances are even the lower frequencies will be fed to your seps.  you might wanna try experimenting as to which of the 3 frequencies you'll use for your seps.
The Devil Drives Prado
mike_parak
kung gusto mo mag subwoofer, use sw control.
if you want the built in crossover for the sub, use sw:internal, kung sa amp or kung meron ka active crossover, use sw:external.
ako naka set sa external kasi im using my amplifier's built in crossover
