2ngkol sa deh-p2500
Started by washworksbats, April 22, 2003, 07:23:13 PM
washworksbats
kumusta kayong lahat sa audioindustriya?may problema ko sa HU ko.ang speaker ko is 6x9 3way ryan audio(high end) sa likod tapos sa harap 2 4"na 80w.bago lang HU ko itatanong ko kung bakit pag nilalakasan ko yung vulume humihina yung ilaw ng HU ko.ok lang ba yung paghina nung ilaw ng HU?anu dapat kong gawin?pwede ko kayang lagyan ng amp?anung watts ng amps?
peace!!!!!!!!!!!
Billabong
kulang ang power na galing sa alternator/battery mo. i guess if you add amps, the dimming of your head unit and lights will even become worse.
washworksbats
tnx!so i decided to put an amp na 4chs para sa 6x9 at sa isang 8" na sub compvr.ilang kayang watts ng amp ?kase balak kong mag-fenton na amp para lifetime warranty.and can u send me a pics of that amp?
tnx ulet!!!!!!!!!!!
washworksbats
Quote from: Billabong on April 22, 2003, 09:37:18 PM
PEACE! BAGO NGA PALA YUNG BATTERY KO SA KOTSE.BOXTYPE NGA PALA KOTSE KO WITH STOCK ALTERNATOR.
TNX.
IMm29
i would agree with billabong.
pag nagpapatugtog ka ba umaandar yung engine?
The Devil Drives Prado
washworksbats
most of the time naka-off yung engine pero pag medyo matagal-tagal na binubuhay ko na yung makina.
IMm29
Quote from: washworks on April 23, 2003, 10:15:57 AM
pero tuwing kelan humihina yung ilaw?  kapag tumatakbo yung makina, o kapag nakapatay?
washworksbats
bale kapag patay yung engine humihina yung ilaw.kapag bukas naman yung makina hindi naman masyado at kapag mahina lang yung volume ng HU.hindi naman totally malabong-malabo kumikirot lang sya.e may balak pa nga akong maglagay ng sub at amp.
tnx!
IMm29
Quote from: washworks on April 23, 2003, 10:44:48 AM
tnx!
looks like kulang yung power na nabibigay nung electrical system mo.  natural yung minsan kumikirot kapag naka-off yung engine, pero when it's running na, baka kapos yung nabibigay na power.
pa-check mo muna yung voltage na nabibigay nung electrical system mo nang umaandar yung engine mo, pero nakapatay lahat ng sounds, tapos i-on mo yung sounds ng mahina muna, tapos malakas.
you've got a few options, among them changing to larger wires (if not yet to spec, as recommended in your component's manual), alternator upgrade or capacitor(s).
washworksbats
ok!thanks a lot!
MABUHAY KAYONG LAHAT!
PEACE!
Billabong
most of the older cars have very low alternator outputs.
so kahit bago ang battery mo, kung hindi naman kaya mag cope up nung alternator(battery charger), talagang magdidim ang head unit mo. by the way, as much as possible, avoid listening to your sound sytem when the car's engine is not running, lalo na kung may external amp ka.
if your alternator is stock, i strongly suggest you upgrade it first.
washworksbats
regarding dun sa EQ ng HU ko,hindi maintindihan yung adjustment nya.
tnx.
mike_parak
what do you mean do mo maintindihan? how to adjust? try the manual dudes.
