L200 at lowrider mags na sumasayad
Started by confused, June 10, 2003, 11:04:32 PM
confused
mga pre may tanong pa pala ako, may mags kasi ako na wire wheels, ang problema ko ay nakalabas ang gulong at mags(offset ba tawag dun) nakalabas cguro ay 3/4 ng buong gulong at mags, pag nakaliko ako ng todo sa kanan ay sumasayad sa inner tire(sa tambol ata at di sa may bumper area) well ang right tire pero pag sa kaliwa ay wala naman, ano kaya ang papaayos ko? camber ba yun or alignment or etc etc.........saka may ideya ba kayo kung magkano ang pa-camber at paalign at san shop, makati area sana, salamat
Freeman
Masyado atang matindi ang offset (negative) ng mags.
3/4 nakalabas? Anong tires and wheel dimensions mo?
confused
15x8 na mags(negative nga ata yung offset non)205x60x15, basta parang palaka yung auto at pag basa yung kalsada ay kawawayung katabi kong auto kasi siya yung nababasa ng gulong ko
Freeman
Tire Width is 8", diameter (height) is 24.7".
I thought your tires would be overly wide and tall for your lowered L200. But it isn't. Now I'm scratching my head with disbelief!
I believe you should change your wheels with one that has no offset or one with a positive offset.
