What SoftWare do You Use foR RipPing?
Started by WaZ, June 26, 2003, 11:46:52 PM
bravoman
Acoustica MP3 CD Burner 3.01  ;)
all im one
tebenets
I use Musicmatch, RealOne and Nero.
Guys I just want to know, how can you rip cd that are Copy Controlled?
4var
is there a ripping program that copies the titles of the songs (of course the source disc should have titles)? i use free rip kc and you still have to type the titles one by one before you rip it. or is there a setting in the program itself?
thanks!
Quote from: 4var on July 05, 2004, 10:29:20 PM
thanks!
Wala po atang program na ganun. Before ripping query first to the CD database para malagyan ng titles iyong mga tracks. Then start ripping. Iyon na rin ang filename nung mga magiging mp3.
dBAGZiq
I'm using Apple iTunes.
Regarding copying the titles, iTunes automatically gathers the title from its database, this also goes do the ripped MP3s, just don't put a pirated CD since the database only recognizes original and copied from original (no rearranging) CDs.
Its free from apple.com
nic
Quote from: Paul on August 29, 2003, 12:00:47 AM
i use musicmatch 8.0. i convert audio tracks to mp3pro. this is a new format. 64kbps lang cd-quality na siya. only musicmatch and strangely nero burning rom can play this at cd-quality. play mp3pro in other players, it will be treated as 64kbps. musicmatch has its own burning tool or you can use nero.
so pag ginamit ko tong mp3pro sa car pangit tumunog? Meron ba ordinary mp3 lang sa musicmatch?
mavERICk004
Quote from: WaZ on June 26, 2003, 11:46:52 PM
what software are you using for ripping only ,
for converting music from audio cd to mp3s?
iam using audio catalyst before but when i switch to winxp the program didn't work na :)
what software can you guys suggest ty  :)
if your using Macintosh i would suggest yung YAAC or yung NMP3 Ripper, i dunno if meron din nun para sa PC...try mo sa download.com, madami audio software dun.
Protege Mania
Im having one huge problem with WMA/MP3s 2since I bought my HU.
Yung ibang CD kasi, copy protected, so Windows Media Player lang puwede mag-rip. Nung ginamit ko nga yun, tapos nag-burn ako, lumalabas pa din sa HU "Protect", kahit yung mga galing sa CD na hindi protected, nilagyan ng WMP!
Kapag nag-burn ba ko na kasam yung license folder mababasa niya to? Sa WMP pa naman, mas OK ang WMA kesa MP3 kasi yung MP3s medyo bright at the same bitrates (I use 96kbps).
Bruticus
I had a CD burned dati. Yung guy nag burn ng CD also did something sa Nero, aside from burning para raw hindi tumalon yung cd while playing. What is this?
soccerjoe5
i use itunes :) it doesn't really matter what software you use, just use the proper settings  ;)
SpdFrk
Quote from: Bruticus on March 06, 2006, 09:25:53 PM
try lowering the writing speed sa mga 52x na blank discs, example from 52x na writing speed gawin mo 24x or lower yung writing speed sa nero. medyo mabagal sya magburn pero mas precise naman ang pagkakaburn nya and totally skip free. unless yung music file na binuburn mo may skip na talaga di na macocorrect ng nero yon. i use 24x usually sa music cd's. for data much lower speeds
ment
Loyal CDEx user here since the dawn of CD Ripping ;D
niwrad33
Quote from: tebenets on May 27, 2004, 06:53:47 PM
I used JetAudio with no problem whatsoever!  ;D And i can even choose whether i copy on the original wave format, convert it directly to mp3, ogg, and other formats. And has also a converter, both video and audio. ;D.
