Brake problems
Started by Jimmy, July 02, 2003, 01:12:27 AM
ment
try mo na lang i-check muna yung brake pads / linings mo .... this they're thin na have them replaced.
But if makapal pa check mo kung may brake fluid ka pa.
Kung merun pa try mo ipa check yung drums / rotors if they need refacing....
Kung di naman problem yung rotors / drums ipa-bleed mo yung mga preno  mo
If everything else fails have the mechanic check your brake system comprehensively na .... either the caliper is stucked up or your brake master is failing na ....
