how long does replacing the timing belt and/or fuel filter take?
Started by DTNS, July 09, 2003, 05:22:49 PM
ignited05
Mabilis lang un mabe lass then an hr. just make sure you get the belt adjusted to avoid squeeky noises
ment
kung skeptical ka go for casa ... at least mataas ang percentage na ok ang gawa .. pero may mga shops naman na cheaper but reputable din ang gawa.. nasa know how and tools lang talaga
Timing belt and fuel filter should consume less than 2 hours given na walang load ang mekaniko kundi sa yo
Kung papalit ka ng timing belt change the tensioner bearing, o-ring, and also the water pump. para isang beses na lang labor. kc ang water pump ganun din mga 80T dapat preventive na rin na palitan na ....
After changing the timing belt i highly recommend ipa timing gun niyo na rin to check if ok pa yung timing. para sabay na adjust sa advancer if ever.
And yeah use original timing belts ... tensioner bearing for me basta KOYO, NSK, NTN ang brand walang problem since these are OEM suppliers. and much cheaper pa!
