Overhaul ng makina ko!!!
Started by nick, July 17, 2003, 07:05:40 PM
nick
Last april pna check ko ung auto ko.... medyo palyado kse.... sabi nung mekaniko nababasa daw nung oil ung spark plugs, pinalitan nya ung spark plugs and ung rubber ba na located paikot dun sa cover ng engine pra hde lumabas ung oil.... e d ok na, sabi nya pg ngyari ulit un e malamang kailangan na i-baba ung makina pra maayos..... den kanina while im on my way home, pumalya nanaman ung auto ko..... bukas dadalhin ko ung auto pra matingnan.... does dis mean kailngan na ibaba ang makina ko?
by the way, my car is a Volkswagen Polo Classic '96..... 50thou. km. pa lang tinatakbo....
tsaka kung ipa-overhaul ko na nga pala ung auto ko, e balak ko na rin ipa-port polish ung makina.... sayang e para isang gawaan na lang..... wat do you guys think? may alam ba kayo mekaniko na gumagawa nito? mga magkano kaya abutin? tnx in advance....  ;)
-=[i love street trucks, 4x4 pick-up's and old skul cars]=-
my two cute babies!!
[img]http://photos.friendster.com/photos/52/42/2552425/1138157869
Elloyd
nakita mo ba mismo na basa ng langis yung mga sparkplugs mo?
overhaul involves lots of money and downtime kaya better get a second opinion from other mechanic. get your car compression tested. do you blow bluish smoke out of your tailpipe or is the palya with oil in sparkplug the only basis of your mechanic?
dude,
check if the oil in the plugs comes from the valve cover. im quite sure na sa valve cover nga galing yan. better get a second opinion from other mechanics.
nick
tnx mga peeps.....
got it fixed na knina..... its jst the hi-tension wire, sira na daw n kailngan na palitan, regarding naman dun sa spark plugs ung isa dun sa apat e basa ung pnaka-dulo, galing sa loob ung oil... pro hde pa naman kailngan ibaba ung makina. (haaay salamat at hde ako magastusan!!!) hehehe!!! ;)
Elloyd
Quote from: nick on July 18, 2003, 02:04:53 PM
tnx mga peeps.....
u mentioned that you changed the sparkplug seal, maayos ba ang pagkakabit? usually, the seal can cause what you're experiencing.
damaged valve seal can also cause oil on the sparkplugs.
nick
ok naman pgkaka-kabit, malutong n luma na daw kya kailngan na palitan..... smooth na takbo ng auto ngyn. hehehe! tnx 4 d help guys.
