Stain Removers
Started by DAPA™, July 19, 2003, 01:59:36 PM
DAPA™
Ano ok na stain remover para sa mga car seats, etc? For example natapunan ng coffee, etc.
I found my "Honda" with TYPE ONE
eley
well, it really depends on how dirty is the interior. you can try the turtle wax power out upholstery cleaner or you can try eagle one or meguiars all purpose cleaners. good luck!
teammgwrs
Dapa,
always remember to use first the least agressive cleaner and then try it sa small portion lang to see if there will be difference, you don't want to make things worse ;)
Teammeguiars Bonifacio Global City and Teammeguiars Imus K-21 Service Center
(02)[email protected] City
(046)[email protected] K-21
Service Hours :Mon-
theveed
organic spills such as coffee needs to be taken care off using water based products. It's best to take care of it ASAP as the longer the stain sits on the fabric, the more it'll discolor the fabric.
best to use warm water with light soap suds first since you need something to dissolve the sugars.
don't rub the stain into the fabric like most people do, doing so will only clean the top part of the fabric and push the stain lower into the foam cell.
always dab the stain, not rub...
PM me if you can't remove it after your initial try.
David Lee Tong
Founder: Pinas Auto Detailiny
