Ballpen ink on leather...
Started by Lance_R, July 31, 2003, 01:40:10 AM
Lance_R
How can i remove a pen ink on leather seats. Ive tried scrubbing it with shampoo, waxing, even rubbing. Would kerosene work? pls. help...
use APC all purpose cleaner of meg...
it will do the job... and use a toothbrush to scrub it off...
theveed
wd40 on a cloth... don't use abrasives!!!
David Lee Tong
Founder: Pinas Auto Detailiny
WaZ
Quote from: theveed on July 31, 2003, 09:57:43 AM
what if matagal na matatanggal pa ba ito ?
Lance_R
Ayaw sa wd40... :'(
Palagay matagal may 1 week na din un e. Dun ko nakuha un nung inawan ko sa paintshop. Dami talaga hassle... :(
Anymore suggestions po. Calling the detailing gurus help please...
Wolverine
There is a product called "Goo Gone"  It is a lemon oil and kerosene based cleaner.  You might be able to find some in Tru- Value.  It is usually very safe on stable dyes but try it on a small portion first.  if you can't find it, Kerosene or Paint thinner will work.  be prudent when you use these and test for fading in a hidden area using a cotton bud.  The paint thinner to use is the one that is for enamel. (the slightly oily one) Do not use acrylic thinner because this will surely damage your leather.  Hope this helps you.
