Suspension Tech
Started by Leepu Awlia, February 27, 2005, 01:03:30 PM
nikko_m
Quote from: stranger on December 01, 2006, 09:33:16 PM
ok lang ba na likod lang ang babaan?just to have a bit of sporty look,mga 1in lang or so.car is a 98 corona.tnx
sir,
why would you want to lower your rear's lang?kung may sakay ka sa likod baka mas mataas ang front end ng car mo.better cguro kung pantay ang pag ka lower ng car.
badtoy
nice read...
just a question. If the car doesnt have a swaybar equipped in the front, can a lower arm bar for the crossmember compensate?
rkdf
good day everyone.
about tire pressure lang po.
nabasa ko sa first page lowering front tire presure increases "understeer" and lowering rear tire presure increases "oversteer"?
question ko lang po,
di po ba when we lower the tire pressure, the tire gets softer, therefore increasing the contact patch of the tire in the road, hence more grip. so di po ba lowering the tire pressure in the front decreases  "understeer" and lowering rear tire pressure decreases "oversteer".
enlightenment would be appreciated. :)
thankyou. :thumbsup:
tougeattacksid
Yeah. I personally, (on my S13 back in the States), like to run 25-28PSI in the front tires and 32-35PSI in the rear , whenever i drift, so it would have a nice tossable feel to it. I used this even before i got my TEIN Super Drift coilovers.
Tires are EVERYTHING when it comes to handling.
Quote from: badtoy on December 11, 2007, 02:28:44 PM
nice read...
plus they make rear swaybars for cars as well =)
javejackpot
Quote from: nikko_m on March 18, 2007, 02:49:52 PM
sir,
one more thing, by just lowering the rear, you're already compromising your car's handling. its way better to have the front and rear lowered instead of just the rear
blur
hmm now i know why my car rolls to much during turns.... im missing my rear sway bar... i noticed it when i installed a rear lower tie bar.... i believe SiR's come with a sway bar right??? mine is missing
ozzyzero
yes it comes with sway bar
orlacx
is it ok to put only lower tie bar, instead of sway bar?   ???
blur
i believe sway bars mas importan than tie bars  :)
what is the difference in performance between 2-point and 3-point strutbars?  ???
Quote from: blue TRD on September 02, 2009, 07:31:22 PM
if you aren't pushing it to the limit, not much.
besides, the firewall ain't that strong enough to resist the "push" coming from the 3 point strut.
2 points are good, but if you have the extra cash, 3 points wouldn't hurt.
sneha3047
Good post it is very informative.
thanks
mikbik
what is the tolerable drop in inches for our country roads? the car is daily driver w/ koni setup
aylaisabelle
There's no tolerable drop theory. Roads in our country isn't flat at all. kahit mukang flat bouncy parin kasi wavy ung pagkaka palitada ng daan.
so pag lowered ka, ramdam mo lahat ng ka imperpekto ng mga daananan sa atin.
ung akala mo ok na di pala ahah..
Pero ganda naman tinganan ng kotse kaya ok lang heheh.. :)
