February 25, 2021, 01:48:20 AM
AMP and SUB inquiry
Started by mackkcam, April 04, 2008, 10:58:24 AM
mackkcam
Hi Guys,
ASk ko lng kung Ok na ba tong setup na toh, kung balance na xa at busog naman ang SUB?
2CH x 350W RMS @4 Ohm 14.4V Bridged + DD1512 Rated at 450w RMS @ 4 ohms
Quote from: mackkcam on April 04, 2008, 10:58:24 AM
Hi Guys,
So power mo yun two subs with 350W RMS each is that correct? If ganon nga, yes tama naman yun power mo for the subs.
mackkcam
No, you got me wrong, 1 Sub lng yan 1 pc DD1512 currently kc yan ang design ko sa project ko kaso mukhang bitin daw? ibridge un, pero naiba na yan kc SoundMogus Amp yan, pero OK pa rin noh? now im deciding on these 3 setups
Sub: DD1512(450wRMS @ 4ohms) or Hifonics BX12SQD4([email protected]) - deciding on Sub Performance and QUality.
Separates: Focal 165A1 or Polk DB 6501
Amp setup 1:
Magus C160 2CH x 350W RMS @4 Ohm 14.4V Bridged (Sub)
Magus 2CH x 180W RMS @4 Ohm 14.4V Bridged (Seps)
Amp Setup 2:
Crunch 325.2 [email protected], [email protected], [email protected] (SUb)
Crunch PZi175.4 [email protected], [email protected], [email protected] (Seps)
Amp Setup 3:
RF Punch P500-2 (Sub)
RF Punch P200-2 (Seps)
Sana may makatulong.... huhu help me naman pWease? :wav:
I suggest getting a smaller amp for your sub or getting a sub with a higher power handling capacity unless you plan on frying your voice coils if you plan on going with Amp setup 2.
For amp setup 1, the HiFonics at 600w can handle the 350w x 2 bridged power, but the DD1512 might overload and fry up since you'll be feeding too much power to it.
smoj_25
Help please....
How about my set up, a kicker solobaric S25L5 dual 4ohms 750W RMS, I have a kenwood PS1D Mono at 2ohms 1200W RMS pwede rin 4ohms at 600W RMS PEAK is 2400W.... in computed 6 cu. ft ported box
Ano po suggestion niyo on how to wire, if I use a parallel wiring for my sub it will be 2ohms at 750W RMS, pwede po ba si ampli at 2ohms 1200W RMS? Kasi di pwede e-series ung connection ng sub kasi it will create an 8 ohms...... Sabi sa manual ni kicker, dapat po naka tap lahat ng coils niya so pipili lang ako sa series and parallel where series is never never an option...... ano po dapat kong gawin???
Thank you.
paolo_sandy0312
OK ba gamitin amp na V12 mrv F905 pang drive ng sub???
Quote from: smoj_25 on September 04, 2010, 08:01:18 PM
Help please....
Thank you.
If you amplifier is rated to go 1200W RMS @2 ohms I'd say maximize its potential. That is if the figure is published, pag hindi published yan on the manual, extended playing might fry it.
Quote from: paolo_sandy0312 on May 04, 2011, 11:33:03 AM
Pwede naman siya magdrive ng sub. Depends on what sub and power requirement.
