February 25, 2021, 12:58:48 AM
Storm HID
Started by czn030, November 14, 2010, 06:22:17 AM
Actually, it's luminance.  Measured in Lux or Lumens. Yung obsolete term is candlepower. ;)   Luminosity is a term used in astronomy.  Yup, you have to convert to projectors.
czn030
Ah. Hehe. Type R kasi yung headlamp ko kaya medyo nanghihinayang pa ko iconvert to projector type.
Ah ok, here's a suggestion. Mag add ka na lang ng aux lights or fog lights na 55 watts halogen. Malaki tulong ito sa rainy nights mo kapag di kaya ng HID mo. This way, you don't have to invest sa projectors and keep your type r.  Yellow para JDM :thumbsup:
czn030
Quote from: Vivo on December 05, 2011, 10:36:10 AM
Mau foglights ako kaya lang di gumagana. Faulty wiring daw. Hehe. I'd go with your suggestion!! Galing!
Quote from: czn030 on December 05, 2011, 11:23:08 AM
Did you convert your Type-R headlights to LHD already? Malaki improvement niyan if you do it. I did it with mine before. As for your fogs, have a qualified electrician re-wire it for you. Sayang din.
czn030
Not yet. Pano ginagawa yun? Yung fogs naman ay ok. Wiring lang talaga at yung switch mukang defective na. Thanks!
Quote from: czn030 on December 23, 2011, 09:48:08 AM
Some cars have a switch levers at the rear of the housing. I don't know about your headlights. I think they have adjustment screws.
czn030
I haven't checked the foglights about the switches. A car electrician has already checked it and found out that the wirings were faulty. Aayusin na rin sana nya that time kaya lang nagmamadali ako kaya ang pinagawa ko muna ay yung wiring ng signal light. About the headlights, I bought them from a friend who sold his car years ago so I'm not sure if they were already converted or not.
You will need a local LHD headlight also. The black chrome frame on the CTR headlights can be removed, transfer that to the local LHD headlight then you're good. You'll have the bulb cover pa since the local version has it. This somehow improves the projection of the light in some way. Then of course being LHD oriented, you'll have proper vision now and cars on the other side won't be pissed at you anymore because your lights aren't pointed directly at them anymore.
czn030
Quote from: Brent on December 23, 2011, 12:56:10 PM
I see. At least I still have the original headlights. I also noticed that there's no bulb cover. This could be the reason why the light is scattered.
