January 29, 2020, 04:48:30 am
HYUNDAI EON GLS. QUESTIONS LANG PO.
Started by mikaela1129, August 09, 2015, 02:05:01 am
« AC problem | 2006 Lancer Cedia Not Starting.. »
mikaela1129
Magtatanong lng po. Last month , nakabili ako ng Hyundai Eon GLS. Ngaun below 1000 km pa lang po mw natatakbo ko. Kapag mabilis takbo ko, around 60 to 90 kmh, maganda takbo, smooth cia. Pero kapag nasa slower speeds like up to 40 kmh (caught in medium traffic). ganito po aking experience. Nasa gear 3 ako, nakaapak sa accelerator, speed ko ay around 40 kmh, then habang tumatabo ako, then nirelease ko accelearator to reduce speed, after about less than a second, prang nag eengine brake, then nagiging hindi smooth takbo for abot 2 seconds (parang tumatalon ng mahina). Mas naeexperience ko po ang ganito kapag mas mainit na makina ko ( running about 30 minutes) . Nagtanong po ako sa service nila, sabi normal lang daw po yun. Gusto ko lang sana po macheck, if may problem car ko, or maybe my driving style. May naeexperience din po ba kau na ganito? Normal kaya po talaga ito sa eon? Please help po. I need advice. Thanks po
Yutakuroyoshi
Cguro going into stall ang makina dhl s lower running speed vs engine speed in 3rd gear. Try shifting to a lower gear when apparent stalling happens again
MAJ_TOM
Is it a manual transmision? When you slow down, do you step on the clutch asap? Or brake pause clutch?
kwiki
ganyan din samin nang bago pa. hesitant ung engine na parang mg stall. after few months bigla nlng nawala. ng stick lng kmi sa low octane gasoline/unleaded. and now, 1 year na xa, so far so good. smooth na eon namin. :)
