AMP wiring newb
Started by zn7, November 18, 2015, 03:32:42 PM
zn7
I have an amp I plan to mount in my trunk. I plan to tap into the head unit's output and run the wires to the trunk to plug it in the amp input.
My question is for the amp output, is it better to run all the amp output wires back to the front where the existing speaker wires are gathered or should I just run the outputs to each speaker individually. What are the pros and cons of each?
stagea
Quote from: zn7 on November 18, 2015, 03:32:42 PM
Run the wires to each speaker if you can. The lack of splices and the reduction in resistance can be worth something.
