January 29, 2020, 04:20:13 am
Questions on replacing Flywheel of 4DR5
Started by patt, February 09, 2016, 05:27:59 am
« engine oil | Honda VTI 97 »
patt
Hello everyone!
My jeep is due for registration this week or next. Problem is sometimes the flywheel turns and sometimes it doesnt. I might have to replace my flywheel on my jeep`s 4DR5 engine (maybe may bungi na). (The electrician ruled out the bendix/solenoid as the problem)
My questions are:
1) Is it possible on the 4dr5 to reverse the flywheel so the good teeth engage the starter teeth?
2) Does the engine need to be brought down, or can it be done with the flywheel side lowered enough just to gain access to it?
3) Can any mechanic do the job, or do i need a machine shop for replacing flywheel (if need be)? I have no idea how the flywheel is attached to the crankshaft. Is it labor intensive?
4) How much kaya sa labor and sa surplus flywheel (from blumentritt right?)
Thank You!
patrick
