How to avoid... what to use... & where to buy?
Started by RaV4.2, February 18, 2006, 09:38:11 AM
RaV4.2
I have a 2001 rav4... and i just had my battery and mount removed and i discovered may rust iyun battery mount nya. How do i avoid yun rust coming from the battery?
Also di ba sa rav4 meron sya iyun rubber lining around the windshied.. Iyun sa passenger side the one near the battery cowling may small piece of rubber lining got loose. How do i paste it or glue it back? what compound do i have to use?
TIA
We import OEM radiators, condensers, evaporators, aux fan, steering rack and pinion etc...
For inquiries pls call 09175262406 09228501132
Is your battery a maintenance free type or one that you need to add fluid periodically? Changing to a maintenance free type might solve the rust problem but I suggest you bring your car to a rustproofing specialist like Ziebart to treat the rust before you get a new battery.
RaV4.2
Its maintenance free. Used to use iyun u have to add water but its a chore... especially with rav4's coz meron syang cowl cover and it sucks when u check ur battery and u have to remove 5-6 locking clips.  Anyway thanks... will do that soon. Right now am sandpapering my battery mount then gonna be spraying 3-4 coats of anti-rust primer... then automotive paint.
The rust probably formed when you had the old type of battery. When the fumes or liquid spills out it tends to corrode the metal underneath.
RaV4.2
Hey thanks for the inputs!.... oh yah about the rubber moulding thingy thats attached to the windshield that came loose... what compount do i have to use to make it stick again? Also am gonna add this na rin... To all rav4 owners where to you buy your battery cowl cover locking clips? iyun plastic parang screw?
TIA
It's supposed to stick to the windshield? You should probably use Silicone Sealer.
mikelsy,
about the battery mount rust, a helpful DIY would be rust converter. Buy like the Tulco brand 1L P80 lang. This shall be a great primer to anti rust coating. May curing period din to.
I also experience the same using the non-maintenance free batteries. It happened nung nalubak ako one time when the NLE was being constructed lumabas yung water ng batt. I figured out that as the cause.
regular silicon glue can do the trick for the rubber. Apply just the right amount so when you stick the rubber back the glue won't get oozing out. :)
