HELP! Car Won't Start, No CEL at Ignition ON (Corolla Bigbody Gli)
Started by scaryghost, September 07, 2015, 09:54:32 AM
scaryghost
Help needed... car does not start, and noticed that check engine light at dashboard was not turning on when I switch key to ON. I checked all fuses and found none busted... replaced CEL bulb with known good bulb, still no CEL light at ignition on. checked W pin at diag port with volt meter, says -11.5V.
car cranks but won't turnover... mechanic says ECU may be dead, but just want to ask you guys for any advice before I replace it. thanks in advance!
Might be ecu since there's no cel.
t2erns
autotechnician /diagnostics / repair 09169784616
ej mobile auto-tech
