Altis 1.8G vs RAV4 1.8 SV
Started by DTNS, January 15, 2004, 05:59:04 AM
which do you think is faster? given the following considerations:
-they both use the same engine
-the Altis is lighter but uses an automatic transmission
-the RAV4 is heavier but uses a manual transmission
KeWlRyDs
#1
hmmm...i'm stumped. faster in what sense? acceleration? top end speed?
i actually have an answer but i'd like think it over once more before i post it. ;D
El
project vehicle????  ;D
kung top speed..i guess di magkakalayo yung 2..yun nga lang...mas stable siguro yung altis on higher speeds... not unless baguhin mo setup ng rav4 mo
kung faster in terms of acceleration sa drag racing... always may edge manual... pero would you seriously use either of the two for drag racing :o..if you really want a drag car... mag 1.6 ka na altis na manual or 1.8 na manual if meron (1.8E????), which i am not quite sure... ask raymond na lang hehe
VTi-S
mga pre, diba yung engine na inilagay sa RAV4 SV ay engine ng altis?
-Andrew-
Quote from: VTi-S on January 15, 2004, 06:24:55 PM
yup same engine. pero i would think pag abot sa strip, mananalo altis. stock to stock.
nonie
Meron na pong altis 1.8E, manual tranny.
Quote from: eL on January 15, 2004, 10:26:37 AM
Sinong Raymond, ako ba? hehehe
Going back to the question, I believe that the Altis is somewhat faster still. Overall mas magaan pa din siya sa RAV4, and somewhat lower ground clearance means more downforce (although mataas na din ang Altis, but lower still than a Rav) , hence more confidence during driving , hence more speed.
wala pa ding 1.8 Altis na manual :(
As for project car, both OK naman iyong dalawa, although tingin ko mas OK palitan ng 2ZZ-GE/TRD supercharger iyong RAV, you have to change the rear drums  to discs though for better stopping power.
GRaMLyTZ
  The car will win in the straight line given stock to stock . Magaan , mas mababa ang ALtis sa Rav4 so may edge ang Altis .
Self Pity
I never saw a wild thing
sorry for itself.
A small
WaZ
given the same driver sa tingin ko altis :)
stradale
If they have the same weight, the manual RAV will likely outdrag the automatic Altis but I doubt if the RAV weights anywhere near the Altis.
Top speed? No question the Altis will win, matic or not. The higher drag coefficient and ground clearance of the RAV will limit how fast it will go.
kiro
#10
Quote from: nonie on January 15, 2004, 08:42:40 PM
i think the 1.8E is still automatic...  by the way, i'll go for the altis ;D ;D ;D
devastator
Eikichi Onizuka
akala ko 2.0 ang rav4? anyways i go for altis for better ground controls :D
See you soon guys!!!
Huh? Where did you get your info? Are you even in the Philippines? Last time we were with Toyota officials, they said they still do not have one. And they won't have one in the near future.
Toms Sawyer
Rav4 SV po pinaguusapan. This is the 2WD version of the Rav4. It comes with a 1.8-liter engine. The 4WD Rav4 is the one with the 2.0-liter engine.
