Nasfor Race Rules
Started by sixpack, February 09, 2004, 07:49:30 AM
JLme
Quote from: racerx on July 26, 2007, 07:28:57 PM
changing tires—swapping of tires is allowed except when a racer encounters a flat during his run. Only after his run will he be allowed to replace his damaged tires. Example: if a racer uses a set of tires in track A and then wishes to change them for his run in track B, he may do so provided it conforms to the rules stated earlier.
please take note that this is only my wording and the actual rules state the same thing more or less  ;D
what if during his run na flat tires ng vehicle nya? wala na pag-asa to win?
Kind Regards,
J-L from ArabianDrift.com
martinthelion
Quote from: JLme on December 14, 2011, 08:38:42 AM
The race will still go on whether his tires would run flat or would get removed from the knuckle. And take note, IT IS NOT because your tires ran out on you, it would already mean you lost, many racers finished tracks with only 3 tires working, some even on 2 (both axles get broken) but still they manage to finish with a good time.
@martin
I remember a particular race where Totin Macmang actually finished with only 1 working axle. I think it was a race in Davao.
