oil problem?
Started by tifosi, March 04, 2004, 06:35:19 PM
tifosi
the 'low oil' warning light came up yesterday while i was driving so i put in approx. 3 liters of oil today, problem is that the warning still lights up while im driving...
help?
jewo
baka natangal or maluwag ung wire dun sa may oil sensor.......saakin ganun nangyari e.....akala ko naguubos dati un pala natangal lang....
did you check the oil indicator sa dipstick? baka sobra na yung nalagay mo na oil. 3 liters is a lot to add! maybe sensor problem lang yan...
any noticable leaks ba?
1 bit
tama. why dont you check the dipstick muna. baka naman hindi nababawasan and sensor nga lang.
ment
i agree with them .... check muna the dipstick before adding oil ... flooding the engine with too much engine oil is Bad ....
if sobra na nga sa max suggest to drain some ....
its the oil sensor; could be a loose wire. yung skin na praning ako when the oil light turned on. nung pala yung wire nya dumikit sa body.
Teka ano ba auto mo? Bakit naman 3-liters dinagdag mo? Di ka nalang nag change oil sa dami ng dinagdag mo.
jaySiR
Ya dapat nagpa-oil change ka na lng a 1.6L engine requires 4 liters of oil,malfunction ang oil sensor mo ;)
