buy new engine
Started by kirbitoy, April 13, 2004, 01:33:33 AM
kirbitoy
paano mo ba malalaman kung may sira yung bibilhin mong makina? saan ba maganda bumili ng 4age 16valve lng tpos how much ba yun?
ViR
Try mo kay Bong (Antipolo)
09178502088
Sya ung na feature sa Channel 2.
BR
ViR
BlackBlood
usually compression test at leak down test and ginagawa para macheck condition ng engine
gOtBoOsT
compression test mo and para sure dala ka ng mekaniko mo... :)
bruns
magkano mag pa compression test and saan?
kirbitoy
Quote from: gOtBoOsT on April 13, 2004, 10:50:38 PM
oo nga naman paano mo ipapacompression test at yung leak test? nakasaksak na sa kotse mo tapos dadalhin mo sa pagawaan?
clyde
compression tests and leak down tests can be done by simply powering the engine with a battery, safely hoist it on a portable engine hanger or any available hoisting tool plus you need a compression guage tool to diagnose every cylinder.  in most cases, physical visual inspection of external parts must be done specially sensors and other plastic covered parts like dist. cap w/c have high probability of breaking up during transport.
kirbitoy
libre na ba yun pag bumili ka ng makina? o magbabayad pa? saan ba pwede mag testing?
gOtBoOsT
hindi libre kung sa surplasan ka bibili kaya dapat marunong ka tumingin, mas better kung may dala kang mekaniko.. :)
kirbitoy
Quote from: gOtBoOsT on April 15, 2004, 10:59:55 PM
pre pwede ba i drag test yung makina pagka kabit nito kaagad? paano kung nagkatagas pwede ba ibalik yung makina o i-o-overhaul yung makina??
BlackBlood
what do you mean by drag test?? ???
kirbitoy
CtLim
Quote from: kirbitoy on April 18, 2004, 12:41:13 PM
ibibirit ko yung makina.
you have to make sure that it can take it before you take it out for drag.
kaya nga surplus eh. di naman yan bnew na may warranty pa. thats why you have to make sure its ok before you buy it. and it doesnt stop there, you have to change timing belts, plugs, oil... then find out kung may iba pang sira.
pano mo ba ibabalik yan sa binilihan mo kung nasira sa "drag test" mo?   :)
johnqpublic318
You must bring your own compression tester to the surplus engine seller's shop.  The push-in type is inaccurate and you must use a screw-in or threaded type with a threaded adapter that will screw-in the said engine's spark plug holes.
A good screw-in compression tester will cost you over P3,000 but will last for many years.
