Turbo worthy?
Started by hatchfan, May 11, 2004, 03:17:38 AM
gOtBoOsT
yeah Garret T25 on SOHC engines.  :) kapos ang TDO4.
hatchfan
Forgive my ignorance, is the compression test a simple procedure? What I mean is , can this be done by the average auto shops?
z3r0cfm
yup, they just unplug one spark plug for each cylinder at a time and insert a compression tester to measure cylinder pressure.
4G92 DOHC Mivec Turbo
BLUERUSH
gotboost,
what do you mean by "kapos ang TD04"?
hatchfan,
it can be done by any shop with a compression tester. you can even DIY. you can do it wet type or dry type.
do not go gently into the night,
but rage, rage, rage against the dying of light..
tessaj
Quote from: gOtBoOsT on May 12, 2004, 09:51:19 PM
gotboost, yang turbo na cnbi mo, pwde b yan sa lancer 94 glxi? if so, wer can i buy 1 and hw mch kung sakali? tnx :o
GRaMLyTZ
  Popular at less lag sa mga 4G engines ang HKS Super 60 .
Self Pity
I never saw a wild thing
sorry for itself.
A small
z3r0cfm
Quote from: GRaMLyTZ on May 14, 2004, 10:36:31 AM
anong rpm do you get boost onset with this? anong rpm ang full boost?
Quote from: Elloyd on May 12, 2004, 05:46:21 PM
i think honda shaw has a leakage tester but they won't do it in a boosted car and i don't know why.
autoplus can do a leakdown test for you if you like.
gOtBoOsT
agentjapi,
yes pwede ang Garret T25 sa lancer GLXI mo. try to contact ERL motorwerx and look for Ernie or try to pm RS_Sprint.  :)
turb
you mean turbonetics t3 super 60?
hks turbos are the GT series
D'Clean Look Plate Covers
Dealer of New Tag Heuer, Oris, Hamilton Watches
Call/txt 09179551144/0
GRaMLyTZ
Quote from: turb on May 14, 2004, 04:41:48 PM
 Sorry for the confusion , yes its the Turbonetics Super 60 , on the other hand HKS was a different turbine and housing similar to the size of the T3 Super 60 offered by Speedfactor here as kit made specially for the demand on 4G engines .
ZERO CFM : if my memory serves me right , boost is playing in the 10 - 12 lbs area safely with stock internals and in the neighboorhood of 20-220 WHP. As to the RPM's not sure but very early , maybe @ 3500 rpm , i'll have to confirmed on it .
 These only applies to those with Lancers / Mirage with the 4G15,4G92,4G93 SOHC engines .
Self Pity
sorry for itself.
A small
hatchfan
Quote from: GRaMLyTZ on May 15, 2004, 03:53:23 AM
Did you mean 200-220WHP? :o What about the clutch and suspension, do you need to upgrade them?
GRaMLyTZ
 That was only when dynoed , to run consistently in the 1320 @ mid 12's to low 13's , yes a good set-up of clutch , suspension, lightening the car and building the internals for more better results so as to up the boost .
Self Pity
sorry for itself.
A small
