PPI PC2350
Started by chasin_dreams, May 26, 2004, 09:35:16 PM
chasin_dreams
what do you guys think about this amp? im planning to power my 12w7 with this, ok ba to?
thanks
HaVoC
anong specs ng amp na to?
If I were you, I'd look at myself in the mirror and ask, "Now what can I add to my system today?"
chasin_dreams
Quote from: HaVoC on May 27, 2004, 10:38:34 PM
Power Output: 350W x 2
4 ohms
Power Output: 700W x 2
2 ohms
Power Output: 1400W x 1
4 ohms Bridged Mono
THD: 0.02 %
Signal/Noise Ratio: 105 dB
Frequency Response: 4.5 Hz - 100 kHz
Sensitivity: 0.15 V - 12 V
Damping: > 500
Dimensions: 8.9" x 25.25" x 2.25"
QBass: Yes - QBass Plus
Crossover Slope: 24 dB/Octave
Crossover Frequency: 90 Hz
Crossover Type: 2 Way
Internal Fan: Yes
A lot of car audio gurus told me that i should get an amp for the dub7 with at least 1000x1 @2 ohms so that theoretically when wired at 3ohms it would range around 700-800w but im thinking of having this amp to have more power?
comments guys about it...
KeWlRyDs
all i can say is...i want one too. ;D
Fixed ang crossover frequency? 90 Hz lang?
ajsl
yup the crossover freq is fixed at 90Hz
all the rating stated above is @12v
chasin_dreams
Quote from: ajsl on May 28, 2004, 09:15:24 PM
so what does it mean if fixed yung crossover? is it a good thing or a bad thing that the rating is @12v?
ajsl
Quote from: chasin_dreams on May 29, 2004, 12:10:05 AM
It means that hindi mo pwede baguhin yun freq ng amp, ang pwede lang ay hpf or lpf @90Hz, kaya if gagamitin mo yun amp for sub for an sq setup mataas yun freq, so you'll need an external crossover para mabago yun freq, pero kung more on spl ka pwede na yun 90Hz to accomodate more low freq.
For some it is a good thing na rated @12v ang amp para sigurado ka na yan na yun exact wattage ng amp, kasi anything lower than 12v mahihirapan na yun sasakyan, but sometimes it goes a bit higher than 12v so pag mas mataas yun voltage mataas din yun wattage ng amp.
HTH :)
chasin_dreams
thanks ajsl. well i think the sub can handle sq tasks very well that i wont need an external crossover. my cousin has been a fan of ppi amps a long time now and to this particular line that ppi produced. he told me that they're even under rated. that would probably come from the actual rating of the amp @ 12v.
ajsl:
do you have one yourself?
MaD CoW
Quote from: ajsl on May 29, 2004, 01:23:50 AMFor some it is a good thing na rated @12v ang amp para sigurado ka na yan na yun exact wattage ng amp, kasi anything lower than 12v mahihirapan na yun sasakyan, but sometimes it goes a bit higher than 12v so pag mas mataas yun voltage mataas din yun wattage ng amp.
This is not always the case, and in this case, it is not.
Who puts the MOO in smooth[color=r
chasin_dreams
mad cow:
so what's your comments about the amp? is it a good amp to match the dub7? how does it compare with the jl 1000/1?
ajsl
Quote from: MaD CoW™ on May 29, 2004, 06:20:59 PM
Sir Mad Cow,
May I ask how it is not in this case? Tnx!
WaZ
Quote from: chasin_dreams on May 29, 2004, 09:44:54 PM
mad cow:
according to the JL chart, 1000 watts is a little over the optimum level of 12w7, pero wala pa naman sa danger zone, so i think match sila ng sub  :)
koykoy
its really nice that PPI rated their amp at 12v, which most car batts and alts can produce realistically..
if this amp has unregulated power supply, it can produce more when presented a higher voltage.. (wow!)
i really hate amps rated at 14.4 volts because I havent tried reaching that level. the most i had was 13.5
...Life is Beautiful!
Quote from: koykoy on May 31, 2004, 11:17:13 AM
Yeah, but that still depends if the amp has a regulated or an unregulated power supply.
If it has regulated power supply, hanggang dun na lang talaga ang ibibigay ng amp. If the amp has unregulated power supply and it claims to produce more power at higher than 12v source, then mas malakas ang ibibigay ng amp.
Withregards to 90 Hz, medyo di na flexible ang amp IMHO. Wala lang, the 90 Hz is not guaranteed to tailor fit into a vehicle's acoustics.
Although may workaround para dito. Set the amp x-over setting to FULL (kung meron) then let the HU perform sub functions, that is if may sub controls iyong HU.
