Rattling Backboard
Started by charles, August 06, 2004, 12:04:08 AM
charles
what can i do to stop the rattles in my backboard, i think bec my sub is fronting the rear trunk. can someone give me an idea how to stop this? ;D thanks in advance!  :)
KeWlRyDs
adding sound deadening material on the sheet metal under the backboard definitely would help. a cheap soulution is to add pieces of form in between the sheet metal and backboard.
hans
ipitan mo ng papel o goma ng tsinelas yung nagraratle
charles
thanks guys for the reps!  ;D
kbh:
sbi kasi ni uncle francis kahit mag lagay ng dynamat, minimal lang yung rattle, so sayang daw..
-Andrew-
actually kahit anong gawin mo magrarattle talaga yan. kahit nga rear view mirror eh nagrarattle eh pag bumabayo pano pa yun backboard. u can try dynamats and other materials to lessen the rattling but it can never be completely eliminated. that's the nature of it all hehehehe sorry bro.
Silverado
oo yan talaga problema ng may system... rattles.
ako dati lahat from rear view mirror, plate number, doors, rear shelf, trunk lid...
yung sa rear view, nilagyan ko ng rubber, yung suction cups ba. i folded it and nilagay ko dun sa contact point nya.  ayun na solve di pa halata kasi black din.  dati pag nagpapatugtog ako nakakahilong tumingin sa rear view kasi grabe yung pag vibrate... ;D
yung sa plates ganun din, rubber material din ang nakasolve.
sa doors, nag flashband ako.
yung rear shelf na lang ang aayusin ko pag may time ako. gagamitan ko ng foam and flashband.
yung trunk halos ok na inayos ko lang yung mga wires and binalot ko sa tapes.  syempre inayos ko din yung mga tools para di kumakalog ;D
aka Wrecker
charles
ah i see.. thanks guys for the reps!
1 bit
you can also try foams para siksik. effective din.
charles
Quote from: 1 bit on August 12, 2004, 08:29:31 PM
ah ok.. thanks, i'l post here na lng after i've done it na.. thanks! :)
