Stebel Nautilus
Started by meowmix, October 20, 2004, 10:31:40 PM
glock26ph
Been using the Nautilus for almost a year now.  Just replaced the stock horns, relays were not needed anymore - so said the shop people.  My car's an old corolla 101.  Used to notice my lights dimming a bit when I press on the horn button long enough.  I had my grounding wires upgraded a few months ago.  The Nautilus is really loud.  I used to get annoyed with "deadma" pedestrians and crazy drivers.  Now, people jump out of the way whenever I give them a full blast of the Nautilus  ;D.  A short quick tap on the horn button would produce a less intimidating report.
meowmix
When you say upgrade of ground wires, what exactly is changed?  The ground wire from the battery's negative terminal to the car body, or the ground wire of the equipment to be installed, i.e. Nautilus?
foh
around how much are these horns? sira na yung stock horns ko and i'm thinking of upgrading na rin
archlan
ok a!!
how much ito?
at saan pwede pa install?
MEMBER: United Architects of the Philippines
- Metro Chapter-
meowmix
A friend of mine already bought one for about P1,100 ata (no installation - she still has not decided where to have it mounted). My friend bought it at one of those auto stores near the riles ng tren near Buendia.
SOHC-T
sir sa auto circuit 900 lang yan with installation... ewan ko lang kung nagtaas na...
Yeah try to get from Auto Circuit or C3, they're both in Banawe. They prices are very competitive.
AFAIK same price padin.
archlan
Quote from: SOHCme on October 26, 2004, 11:33:13 PM
auto circuit? saan yun?
- Metro Chapter-
Quote from: kiamy on October 27, 2004, 05:54:29 PM
Its in Banawe, beside Bruno's Barbers. Try clicking on their ad in the main page for more details.
EK3 Ferio
I just had a set of Magnum2's installed a few days ago. Just today I went back to AutoCircuit and installed an additional set of the Nautilus. Now they told me you could not have them be firing at the same time since you would burn your relays. It wouldn't last daw. So I just had a switch to play between the Nautilus and the Magnums. Can't I have them fire at the same time? ???
charles
Quote from: EK4 BaN@nA FeriO on October 27, 2004, 07:27:47 PM
i used 2 nautilus, a pair of magnums and a pair of fiamms at the same time ;D
EK3 Ferio
How do you do that? What kind of wiring was done for your setup? ??? Thanks.
Quote from: R_8 on October 27, 2004, 07:35:15 PM
You sure are one crazy fool. Damn talk about loud. How big a battery do you use anyway? The current draw for those horns will definitely drain it.
archlan
900 each? so kelangan ba dalawa yun?   ::)
- Metro Chapter-
Quote from: kiamy on October 27, 2004, 08:25:12 PM
Nope just one will do. Malakas na ang isa. Pero kung kulang ka talaga sa pansin, at gusto mo talagang marinig ka kabit ka ng dalawa.  ;D
Personally I use only one. Similar setup with EK4_Banana, pero I use TM-80 instead of Magnum.
