kasalan ko ba??
Started by edong, May 31, 2005, 09:51:12 AM
edong
hello bro's & sis,
       just wanna share to you what had happened yesterday...i have a friend who's selling his 93 gli(itlog) to me...the car looks good, only just for some body repair particularly on the right rear wheel (yun base ng shock's) w\c has a hole already, kasi daw nabangga na yun dati, at di maayos yun gumawa ng auto nya...when we were alredy on the engine bay, ok din naman malinis, so he started the engine, ok din one click lang start agad...so what i did i try to pull off yun high tension wire ng spark plug #1, then ok naman di naman masyadong nag rattle yun makina nya...so binalik ko yun high tension wire #1 sa spark plug...then ok ulit yun makina(smooth na ulit)...then i pulled off naman yun high tension wire ng spark plug #2, but the engine rattle's more comparing dun sa nauna...so nung nanginginig na yun makina...my friend turn off yun engine nya....then we he tried to start again...di na nag start yun makina nya...[/u]ano kaya ang nangyari?? tama ba ang ginawa ko?? kasi ang pagkakaalam ko it's on way of checking kung ok yun makina ng isang kotse.... so naghanap na ng mekaniko yun friend ko...at nakakuha sya from Rapide'....what the mechanic did is he replaces all the spark plug, pero ganun pa din, di pa rin nag start yun engine nya....second was he trace kung may possible blown fuse...pero ganun pa din...ang masakit nito sabi ng mekaniko ng rapide' eh baka raw na-apektohan un computer box...anu kaya sa tingin nyo ang nangyari :?:  kasalan ko ba talaga :?:  at mga magkano kaya sa tingin nyo ang aabutin ng pagpapagawa :?: tulong naman dayan...
 sensya na po newbie lang kasi....
