EK9 Stock Spring Rates
Started by Brent, June 22, 2005, 12:35:00 AM
Anybody happen to have the stock spring rates for the EK9? If you have also for the EK4, that'd be a great help too.
Fafa naka book mark sa akin dati yung page, but I lost it already. Somewhere in the realm of 3-4kg yung sa Type R.
EG6-R
Yeah I remembered you mentioning it before. Can't remember the site either. Tried google, pero puro wala specs on springs and shocks. Puro engine specs.
eg6r
Baka meron in kg/mm?
240 lb/in is around 4.3 kg/mm
Same rates for front and rear? Parang malabo naman ata ganyan. Teka nga, exact kaya yun rate sa GT4? Check ko nga dun.
EG6-R
Unusual but remember the front is linear and the rear springs are progressive.
When I checked in GT4 (when you buy fully adjustable suspension), which usually sets spring rates to stock (i presume) by default, it says 6.8kg/mm for the front and 4.2kg/mm for the rear. The rear is very near to the specs given, so I guess this is somewhat it or maybe I could be wrong.
The figures I saw before were something like 4+kg/mm in the front and 2.5 - 4+ kg/mm in the rear, as the rear is progressive, the spring rates vary. Parang mali ata yung 6.8 stock na harap, the black Spoon springs that we used before are rated around 6+ if I'm not mistaken  :)
Quote from: Benj on June 23, 2005, 12:10:53 PM
Oh ok, that is so, then figures from GT4 were probably uprated spring rates already.
So I think I can follow the figures given by EG6R then.
Front 4.3kg/mm
Rear 2.5-4.3kg/mm
Elloyd
san nakakabili ng EK9 stock spring and shocks? hard to find ba mga ito? most of all, how would i know that what i'm buying is a real Ek9 shock and spring set?
both benj (on his former car) and brent (on his car now) used that suspension... maybe they can give you tips on what to look for:)
