All About ROTA Wheels
Started by Hero33, March 22, 2005, 12:01:27 AM
zeagle
Quote from: rota wheels wrx on January 27, 2006, 11:53:05 AM
Gulat nga ako you were able to put that big a tire. Looks like 18 will have no problems in a swift.
Malaki sir yung wheel well ng Swift but maximum width ng rims can only be 7.0. Baka puede pa 7.5 but clearance is questionable na. Medyo risky. So if 18's cgurado sabit na. 18's yata would be 7.5-8.0.
swiftdevil
pwede ba ko punta sa plant ng rotawheels?  anytime?   ;D ???
[email][email protected][/email]
rota wheels wrx
kanina ko lang napansin yung ad ng Rota Wheels sa Jan issue ng C! magazine.
eto ang nakasabi: "100% Bling Free"
nubie
#649
@ Mr. rota wheels wrx
             Hi, what will u recommend na bagay sa civic exept circuit 10's and rsz-r's? Im thinkin bout swapping them. Also,is it allowed to order mismo sa factory? Thanks.. whoa... nice swift mr zeagle, mgkanu kuha mo sa rims?   :D
it's how you drive
rota wheels wrx
#650
Have you seen the new J-mag na?
Picture courtesy of JLB Motorsports
dzeuk_ph
panu po magpost ng pic d2?.. ganda nung bgong wheel..hehehe
zeagle
Quote from: nubie on January 29, 2006, 04:49:57 PM
Si Mr. ROta Wheels WRX dapat mo tanungin. PM him and I'm sure you won't be disappointed.
tougefox
Quote from: rota wheels wrx on January 29, 2006, 06:09:00 PM
ganda a!! what size po yan?? any other colors??
rota wheels wrx
Right now, JMag is available in 15x7 but a 16x7 is already on the way
ZeroXtreme
@ROTA Wheels,
Do you have any models either in 16x7 or 17x7 with 5 holes and PCD 110? It should fit an Opel Vectra Estate 2000 model.
Thanks
rota wheels wrx
5x110. We do have them from time to time. Depends on the order of our european customers. I'll check kung meron ngayon
ZeroXtreme
Quote from: rota wheels wrx on February 01, 2006, 12:03:22 AM
Thanks for the quick reply. Is it ok to post my mobile number here so you may contact me directly via SMS since I am mobile most of the time?
dboy
How does the weight of aftermarket local rims, e.g. Rota, compare with the weight of OEM rims and imported rims of the same size? I would like to go local but Im a bit concerned with weight. thanks.
Quote from: dboy on February 01, 2006, 04:44:23 PM
Compared to OEM rims, Rota rims weigh much lighter. With the improvement of technology today, they are also comparable with imported aftermarket lightweight rims as well.
