rust
Started by tinkerbel, August 10, 2005, 03:53:22 PM
tinkerbel
how can i remove rust (small about half an inch or less) from my plate garnish?-tia
theveed
sand the area down until you dont see the rust spot anymore.
clean it off with a dry, tack cloth, then brush off excess rust powder with a toothbrush.
apply rust inhibitor like Turko/Turbo and other rust stopping agents (can be bought in most tool shops for under 100 bucks
wait for it to fully dry (it usually turns black or grey)
paint over it if desired.
David Lee Tong
Founder: Pinas Auto Detailiny
Quote from: theveed on August 10, 2005, 04:53:59 PM
Thanks for the info. Any advice on what grit of sand paper to use?
I'll follow your advice para matanggal ang mga surface rust sa kaha ng oto ko.
theveed
depends how bad your rust spot is actually.
David Lee Tong
Silverado
I usually start with the least abrasive sandpaper that I have and work my way up (or down if were talking about the grit  ;D).
aka Wrecker
zinggoy
Quote from: theveed on August 10, 2005, 06:27:01 PM
Quote from: Silverado on August 11, 2005, 01:10:22 PM
yup, i agree  ;D  but any grit will suffice. however, it just takes a little longer to remove the rust if you use higher grit. i normally start with 600 or 400 grit then work my way down for more cutting power
Zinggoy's Paintworx
Has moved into a new home...
Fastrack, Capt Javier st., Brgy. San Roque, Pasig City
09186102994
Offers premier
tinkerbel
thanks dude
