starter solenoid
Started by aarongeoff, August 14, 2005, 01:56:17 PM
aarongeoff
Guys help naman! Umilaw kasi yung check engine light ng kotse. Its code 12. Nagpalinis ako ng starter and hindi naman pinalitan yung brushes pwede pa kasi. After 2 days bigla na lang umilaw yung check engine. There are 2 instances that after linisin yung starter ayaw magstart ng kotse but as of now one click lang ok na. Distributor is ok. So were thinking na it's the solenoid or the ECU na. I need  a starter solenoid to check kung talagang solenoid or baka ECU na yung sira. Sayang naman kasi kung bibili ako ng solenoid tapos ECU na pala  yung dapat kung palitan. Pls  if you guys have an extra solenoid para matest lang yung car or could you recommend a shop na matutulungan ako.
stole this from hcp:
from Honda-Tech.com
CEL CODES:
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
aarongeoff
