vibration pag nagbbrake
Started by lekyboy, August 17, 2005, 06:11:02 PM
lekyboy
ano kaya problem pag nag va-vibrate yung brake pedal pag nagbe-brake ng 80km/h?  tapos pag nangyari na yun, nag squeak na yung brake pag mabagal na ang takbo.  nga pala nagpalit na ko ng brake rotor tapos nagpa reface na ren ako.  please help!
No vibrations with the steering wheel?
lekyboy
none on the steering wheel.  sa brake pedal lng po nagva-vibrate.
how bout that pads? have them sanded down...
lekyboy
ilang beses na rin po naliha yung brake pads.  nawawala yung squeaking sound pagka liha pero andun pa rin yung vibration.  tapos after a while, babalik ren yung squeaking sound.
Quote from: MOL on August 18, 2005, 09:35:47 AM
Actually squeaking sounds means you have worn/old brake shims or there is a lot of play with the brake calipers. Non-OEM brake pads will also have the tendency to squeak/squeal.
lekyboy
OEM po brake pads ko.  kakapalit ko lng, wala pang 2 years.  ano po yung shim?  kasama po ba ito pag bili ng brake pads?
Quote from: MOL on August 18, 2005, 09:57:18 AM
Shims are thin metal linings that are placed behind the brake pad. They should be on your car, they don't come with brake pads when you purchase pads. You can order them from the manufacturer (casa) if they are badly worn.
tougefox
baka naman nag warp na ang disc brakes mo??
if you buy honda oem pads, the shims are included in the set :)
Quote from: speedyfix on August 19, 2005, 09:14:53 AM
Wow really?! Wish Nissan pads are like that. I paid 4,000 bucks for new front shims! :P
egzbuen
damn dude! mahal!!! :P what a rip off!!!
Quote from: MOL on August 17, 2005, 06:11:02 PM
I had that problem at the track.  After i replaced my rotors with brand new units, the problem disappeared.
But there are many reasons that could cause your problem. How are your brake pads?   Are they still ok?  The inner pads wear out faster than the outer pads so you don't really notice it till it squeaks.
Also, if you activate the ABS at that speed, it seems that the brakes are vibrating.  This is normal for ABS.
