esi upgrades
Started by chuckster, September 03, 2005, 09:47:26 PM
chuckster
bro, i'm setting up my esi engine. ano ba yung maganda lagay sa engine? sana yung pwede maging daily driven at the same time pag hataw-mode lakas din... ano ba suggest nyo? cams? camgear? anong type? :) thanks
BlueVic_8354
i suggest you start with basic i/h/e, iridium plugs, and you can have your head port and polished. you can also do a mini-me. vtec conversion using 20 lobed d15b head and the ph16 block.
My EG-8
[img width=250 heig
chuckster
thanks for the heads up :) i already have an i/h/e upgrade, open air intake, spoon layout 4-2-1 header, piping and tail end... i did notice improvements in performance, bottom end improved indeed. how much would the d15b cost and ph16 block cost? would the engine still be a daily-driven even with the head and block? thanks again
bRri_GD3
daily driven parin yun....mas madali kung d15b nalang agad kunin para wala ng gagawin modifications... ;D
BlueVic_8354
for the ph16 block... ur original esi block will be used only with provisions for the oil sneder (idadagdag yun). its ok to install d15b direct swap... wala ka na problem... pero as i have read sa mga articles and as my original plan for my esi... considering the 20 lobed vtec jdm d15b head and and 1600cc block it would produce a higher torque... same concept as putting a b16 head to a b20 block mini-me/frankenstein project... and yes it would still be good for daily grind.
My EG-8
[img width=250 heig
chuckster
great! thanks for the info! hehehe will look around this week for a d15b...
turbo mo nalang yan. no better bang for the buck.
ESi engine hehe malakas na yan as is hehe.. mas ok pa yang engine kaysa sa mga vtec  :D
EG6-R
Quote from: BEU_555 on September 16, 2005, 08:44:43 PM
Why would you say that?
Quote from: EG6-R on September 16, 2005, 08:52:27 PM
imo lang yun  :) mas bilib tlga ako sa performance ng esi engine kaysa sa ek and es namin ibang klase talga yun hatak  :)
kenshee19
mga tol, ask lng ako abt d minime conversion.
kng papalitan head ko ng d15b, and dami pang gagawin kse vtec na ryt?
lyk wiring? or wat?
karlsdomain
If you ask me, turbo's too complicated for most driver's.  Unless you take the time to understand how it works so that you can fix it when some minor thing happens, it's not advisable to go that route.  There's more maintenance, both in time and labor.
How far do you think you'll go?  How much is your total budget?  If you have @P50k in the next year, just save up for a B16 swap.  It'll make as much power as a turbo PH16, weigh less and require less maintenance
Jango
ESI engine ang lakas! walang sinabi yung ES ko ngayon sa ESI ko dati... now im thinking... bakit ko binenta yun  ???
id quo maius cogitari nequit
something greater than which nothing can be thought.
mommycar1995
Quote from: Accord GTR on October 14, 2005, 08:33:07 AM
sorry, i don't agree.  with a used t3, pasadya pipes, surplus hardware and a rechipped box with uberdata you can hit up to 200whp on stock internals.  good enough to eat any stock b16.  plus it's way cheaper than the 100k you'd need for a swap.
as for maintenance, just check water and oil levels, all connections and hose fittings every morning. then oil change every 2months.  this isn't too much work - all performance engines need this kind of tlc.
FS eg/ek turbo kit, [email protected] - bb t3, bi log mani, ss downpipe, ss pipes, vr4 ic, dsm bov, 370cc inj - 55k
comp box, fuel reg, boost g
