bubbles sa radiator
Started by Jassper23, October 24, 2005, 09:54:57 PM
Jassper23
Hello...  napansin ko lang sobrang daming bula sa radiator ko na try ko na siyang palitan ng water ganon parin yung bubbles parang me sabon.... pero wala naman amoy yung bubbles... kung titignan mo naman water clear naman kaya di ko alam kung saan galing yung bubbles ano kayang cause nitong ganito  ???
Thanks
Let's get it on.
head gasket or valve seals probably.
when you rev the engine does the water seem like it jumps out of the radiator?
Jassper23
Quote from: speedyfix on October 25, 2005, 08:56:21 AM
Pag nag rerev ako parang wala siyang bubbles and stable water pag naka rev siya... nung nasira cylinder head nya talagang bumubulwak water pag naka open yung takip ng radiator pero ngayon di naman siya.
Let's get it on.
hmmm... didya have the valveseals checked? nagbabasa ba plugs mo? you loosing water?
Jassper23
Quote from: speedyfix on October 26, 2005, 09:08:13 AM
Sir kanina napansin ko me tumulu bigla sa radiator parang nabutas na siya...pa check ko nalang bukas para malaman ko kung yung lang yung sira
Let's get it on.
Jassper23
Sir bad news... nung pina overhaul ko radiator sabi nung gumagawa malakas ang presure ng radiator baka sira ang cylinder head gasket... then pina open ko yung cylinder head... tapos nakita nung gumagawa me mga crack na yung cylinder head 3 ot 4 ata... wala na bang way na ma fix ganitong problem? nag tanong kami ng surplus galing sa RF engine na cylinder head cost 9k. ano pa kaya ang pweding gawin papalitan na yung cylinder head or meron pang way to repair it?
Maraming salamat po. :'(
Let's get it on.
a/c tech
psaingit lang po, sakin po prob ko is madalas mag-overheat, 1 month pa lang radiator ko(new), I noticed when the engine is in normal operating temp, tapos pinatay ko, napansin ko exaust pipe ko, umuusok, at ang amoy is boiled water, at yung radiator ko is meron nang halong oil yung water, kaya kaya ng top overhaul o talagang engine overhaul na, my ride is L300 diesel
jayar:09215478188
Jassper23
Quote from: a/c tech on October 31, 2005, 06:45:58 PM
Ganyan rin problem nung sasakyan ko dati... then pina palit ko ng cylinder head gasket medyo ok naman... pero ngayon kasi medyo malala na kaya parang wala ng pag asa yung cylinder head ng sasakyan ko... pag check mo na sir para makita mo na kung ano problem.
Let's get it on.
a/c tech
iipon lang ako ng pera, hirap talaga pag may ibang gumagamit ng sasakyan! sasakyan ko, di ko gaanong ginagamit kaso lagi naman ginagamit ng erpat ko, napabayaan sa tubig kaya yun nag-overheat and take note! pinatakbo pa rin kahit nag-ooverheat na! tapos ako namumroblema sa pagpapagawa!
jayar:09215478188
Jassper23
Quote from: a/c tech on October 31, 2005, 09:44:02 PM
hahahha same tayo... ako kasi pag pumupunta ng manila gamit ng kapatid ko yung sasakyan ko... then pag balik usually me sira.... ngayon palagi na ko me problem sa sasakyan ko :(. sana di sira yung cylinder head mo kahit pano medyo mura pa yun.... kasi yung saking cylinder head na kaya mas magastos
Let's get it on.
a/c tech
sana nga pre! pero kung kelangan talagang palitan, walang magagawa. hirap talaga ng may sasakyan! magastos! pag nagawa na yung tsikot ko, lalagyan ko ng hidden switch para di umandar, para ako lang ang gagamit.hehe
jayar:09215478188
Jassper23
Quote from: a/c tech on November 01, 2005, 05:50:13 AM
hahahaha... pag wala me pera nito baka january na magawa sasakyan ko.... pero kahit temporary lang na umandar para me service ako sa work... di naman ganong umiinit kasi eh... problem lang talaga meron presure sa radiator tapos mga bubbles
Let's get it on.
a/c tech
Quote from: Jassper23 on November 01, 2005, 09:21:09 PM
baka naman lalong masira yang tsikot mo! ikaw din! baka sa halip na cylinder head lang papalitan, pati buong engine, palitan na!
jayar:09215478188
a/c tech
nagawa na yung sasakyan ko, pinalitan ng dalawang cylinder head gasket yung luma kasi pina repaste na pala ng dad ko yung cylinder head so manipis na siya, yan, umaandar na ulit, ang inis ko lang is naging hard starting ata,
jayar:09215478188
