Evercool radiators leaking.
Started by RustyXIII, December 03, 2005, 08:04:08 AM
RustyXIII
Have any of you experienced leaking with your evercool radiators? I just did. Gusto ko lang malaman kung madalas ba itong mangyari.
so far no problems with evercool radiator in one of our cars. been 2 years already. baka there are other problems with your cooling system that led to the leaking of your radiator.
archlan
sakin naman 1year na pero ok pa din. evercool talga  ;D
MEMBER: United Architects of the Philippines
- Metro Chapter-
Did you fill your cooling system with a 50-50 mixture of coolant and water?
may warranty naman ata right? there should be a green sticker on the top of the rad.
RustyXIII
#5
Yup. 50/50 Prestone coolant and water. The strange thing is, nagkaroon ng leak after I switched from pure water to the 50/50 mix. Related ba yun?
Slightly OT: My heater valve (the thing that lets water into the heater core) got busted. Spewed coolant all over the engine bay. Muntik na akong mag-overheat. Niremedyohan ko para makauwi by looping the hose and bypassing the heater core. Ok lang kaya yun?
So now, the leaking radiator is the least of my worries. May warranty naman kasi as Speedifix mentioned. Hassle nga lang na magtanggal-kabit ng radiator.
DrivenByTheMachine
OT: where can you purchase evercool radiators?  And how much is one for let's say an '89 Lancer GLX?
RustyXIII
Got it from JWR Motor Supply in Binondo. Number is 244-0044. Give them a call.
baka naman yung cap lang leaking. where is it leaking from ba? the top?
RustyXIII
Nope. There is a pinhole in one of the fins/rows in the bottom where it meets the tank. Saw coolant leaking and washed it with water to make sure, baka kako splash lang. Came back and may coolant ulit. Does not happen when the motor is cool/system is not pressurized.
return it or try to claim the warranty if it's still good.  :)
RustyXIII
I will try to return it this weekend. Will keep you guys posted.
kaskasero
Quote from: Conan on December 03, 2005, 04:11:13 PM
whats a good brand of coolant?
Quote from: rahkenrowl on December 08, 2005, 12:18:14 PM
I use Caltex long life coolant, there are others like Castrol and Shell.
DrivenByTheMachine
Quote from: RustyXIII on December 05, 2005, 07:09:13 AM
Any other dealers located in the south?  And what is the price range for these?
