HELP!!! BIG AUTO TRANNY PROBLEM!!!!
Started by caryam, April 07, 2006, 06:41:16 AM
caryam
guys, i dont think i can take this much longer, i have an ek with a b16a eg matic swap,  last night on the way home my speedometer (i just got the sensor changed with a surplus one recently) just went dead then i heard a rattling sound every time i step on the accelerator. then when i got home, i was shocked to find out that i was leaking so much ATF, every stop i make there was a pool. i dont know what happened, i just got the ATF changed a almost a month ago coz the tranny didnt wanna shift when cold, but when ATF was changed, it operates normally. could this be repaired? or is my tranny really f*%#d up? help pls...  :( ???
"You are what you drive"
zoids
was the speed sensor installed properly or did the tranny dipstick not fall off? atf could have oozed out of these two when you step on the accelerator if not installed properly
agree, have it checked muna. refill atf and if it works without problem then you're lucky.
