Motul, Oberon, LE ATF? which is better?
Started by romtrt, August 25, 2006, 06:24:30 PM
romtrt
Sirs which is better? Given all can be applied to my car. Thanks!
romtrt
Thanks for the replies..Where can I get redline atf? How much per li? Thanks Sirs!
Quote from: romtrt on August 26, 2006, 09:53:25 AM
What's your car to start with? You never said what your car was.
Some auto trannys actually require specific fluids. The Toyota Altis in particular has specific requirements which is covered by the Motul ATF-1A.
romtrt
Ok Sir. Ride is 95 Galant..Which should I get? Thanks! :)
If you want to use Motul, you can either use the Dexron III semi synthetic ATF or the ATF-1A fully synthetic ATF.
