Oil Reaction LSD
Started by Dondie, November 01, 2006, 03:48:47 PM
Dondie
Oil experts I need ur help.
Is is possible to get a "negative" reaction upon adding a new type of oil into existing oil?
Say for example adding Motul Gear FF-LSD Type 2 oil 75w90(synthetic complex ester) into existing transmission gear lets just say of ordinary grade.
Will I get negative effects on the tranny or none naman?
Thank you!
144 Mindanao Ave. Q.C.
86 Gil Fern
You'll be wasting the Gear FF LSD Type-2 you'll be pouring in your tranny. Better to drain everything out before pouring in the new gear oil.
yep better to drain full before mixing.
Dondie
I get ur point.
The scenario kase is, below normal level yung oil. May natapon lang, nung ginalaw namin yung tranny.
I have some Motul FF leftover from the other car, I was wondering if its okay na ipang-dagdag ko sa normal grade tranny oil which Honda casa uses.
TIA.
86 Gil Fern
Honda engine oil good for helical LSD or non-LSD tranny.
You can put that Motul oil in but, like the others say, you're just wasting money.
I think, correct me if I'm wrong, the Motul LSD oil is for clutch type or viscous type of LSD?  OTherwise, if it's stock tranny lang, Honda engine oil is fine
if the car is not lsd equipped it will shift better with thinner engine oil lang.
strider0515
sir migs,
wat type ng automatic transmission fluid reqrd sa accord? mobil un last na kinarga.  BTW wat is  lsd?THAnKS
i suggest the Royal Purple Max ATF for the accord.
for the lsd info click here: http://en.wikipedia.org/wiki/Limited_slip_differential
strider0515
many thanks sir migs. I may visit your shop one of this days
